Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
Skeans1
5:38 PM
That almost makes me want to sharpen the new 100' roll of oregon square I just got before even spinning a loop...
Typically most of us production cutting will square a new loop up before it even touches wood and also drop the rakers.
Rob Stafari
8:38 PM
Cincinnasti
I may have worded that funny. It is already factory square, just not simington square. Or are you saying you take factory square loops and improve them before cutting? I can certainly see dropping the rakers where you're at. Eastern hardwoods aren't as forgiving, especially if they've been drying for a while.
Skeans1
5:38 PM
I’m talking factory square it cuts like a turd even with the rakers dropped, even in our hardwoods I’ll do the exact same setup for chains.
brshephard
Stihl saws, Husky women
6:38 PM
MT
Skeans is right, it's worth it to sharpen right off the roll. Just getting a crisp corner with a smooth finish will really help with Oregon chain.
I was wondering if Oregon starts new guys on the square grinder first. Or maybe they only make it on Friday afternoons lol
Semotony
7:38 PM
I've gotten noticible improvement from hitting the gullets with a round file at an angle close to the same as the side of the cutter. Improves Oregon right off the reel
Semotony
7:38 PM
Matt; if I was able to decipher those numbers the learning curve might be different:confused: at this time the next step for me is to black marker the dresser and scribe for a reference to see how much movement on the angle has been dialed in with a look at the result. Original angle outboard will self feed voratiously (too much) cutting that lean in half will be closer to what I want. Found out why that loop hung around untouched for two years, rocked a lot
Time's Standing Stihl
Below me...
8:38 PM
Central Iowa
Exl
8:38 PM
Nice! Nothing like a nice square grind. Just [emoji106]
