- 1:40 PM
- Feb 5, 2016
- grafton wv
hes a hoarderYou don't like it?
I can't get around in my shed. I'm a grinder hoarder. Just trying to make room for a saw or two.You don't like it?
Lolhes a hoarder
Besides, I'm only selling oneYou don't like it?
I use my Oregon just about everyday.Which of your grinders do you find yourself using mostly?
Rs2. Easy to use.I should clarify..
Which square grinder do you use the most?
Scarr makes an upgraded roller bearing slide for the rs2. Can also adjust height on left and right. Makes adjusting the rs2 much betterI should clarify..
Can you show a pic of this height adjustment?
I guess it's not. @srcarr52 might have some more vids of his upgrade, that one is 3 yrs. old...How is that a height adjustment?
I have an rs2 here that he upgraded, and don't see a height adjustment. That's why I asked. Maybe this is an older one.
Loosen the two bolts on the block and slide the whole thing up/down on the drop piece. You have to remove the front dust shield to get at the bolts.
I really want to make a combo round and square grinder. No sense having a $1k grinder that can only do one thing.
