Simington / Silvey Square Chain Grinders Tips/Tricks/Secrets
Sierrawoodsman
2:55 AM
Dayton Nevada
Don't overthink it Anthony. That first pic is just about as good as you're going to ever get. I like a little more forward lean for race chain than work chain. For reference this A recent pic of one of mine. Virtually identical to yours.
Remember also that the camera angles can change your perception a little bit too.
2:55 AM
If you want I have a nice angle finder like the one pictured above if I can find it I'll send it to you...
that was from tractor supply for 30 bucks they make one that folds up as well but not digital
Icepick69
Fart knocker extraordinaire.
2:55 AM
North Carolina
Icepick69
2:55 AM
North Carolina
I need that tooth, that looks great
Icepick69
2:55 AM
North Carolina
junkman
Crush it
11:55 PM
pacific northwest
I like that junkman. I like it a lot.
What would a man have to do, to change his top angle?
On my rs2 i change it by moving the chain holder ,further out i get less angle,like 15-20 ,closer in gives more like 25-30 ,i mill with 15 square ,reg cutting 15-20, 25 is faster but dulls quicker for me.
Icepick69
2:55 AM
North Carolina
I'll try that tomorrow. Personally, I like 22.7 degree. But others like more, some like less. Just trying to find that happy medium. Or just do them all the way I like it.
junkman
Crush it
11:55 PM
pacific northwest
That is a good angle,only reason i go for less is durability if get a dirty spot ,it is all compromise ,22-23 is close to off the roll rslf i get ,and it hold up good.
Icepick69
2:55 AM
North Carolina
I seem to like it. That's where it's set at now, and I don't wanna change it. But the lean is easy to change and or change back. I'll grind a few more tomorrow, with forward lean. And post it. But I can't tell a difference in the cut, from 1 degree to 5 degrees. So what does forward lean really do? And why is it important?
Icepick69
2:55 AM
North Carolina
More will self feed faster,grab harder ,less will help a saw with less power pull a longer bar.and cut a little smoother.
What will, 8 degrees forward lean do? Where is to much then. Let's say a stihl 044. 20" bar. 3/8 x .050.
2:55 AM
I like that better. Should feed with lower rakers.
