Exactly.
Set a raker to the desired height(this means filing one raker), put chain on the grinder, adjust tensioner(for the length of the chain), adjust the height of the wheel to the one you set, turn on grinder, turn handle to rotate the chain if it's set up manually or walk away if it's set up to turn the chain automatically.
If it's a chain you are familiar with and you know you want to drop the rakers a bit more for some green wood the next day vs dead, you just put it on the grinder, adjust the tensioner, adjust the wheel height .005, turn it on and watch the show
or do something else for a few minutes
Just because something can be done quicker using another method doesn't mean it's the best way to go about it. For me doing rakers on a 135dl chain by hand would put a hurting on my elbows, so I set up the Oregon to do them. If I felt the Oregon would be faster or easier on me I'd be using it, now the only chains I do on it are those with the safety bumpers and 325 or 3/8 picco, and I'm primarily doing 20-24" chains(3/8)
That would be nice to use one on harvester chain, do you do those on the Oregon now.
Mine has a bbq rotisserie motor on it, it turns a little faster than I'd like, but I take smaller amounts off. I prefer to do that anyway or you harden the rakers and then you can file them to make a slight adjustment when needed in the field.
