- 1:49 PM
- Jan 8, 2016
- Farmington, CT
*************VERY FRUSTRATED********************
Ok, so i'm playing with the new go pro. used a whole battery taking footage that i'll likely toss.
I have a 440 farmertech crank off the case and one on the case.
Using the one off the case, bare crank, crank bushing, clutch washer, clutch, needle, washer ... there STILL isn't a lot of clearance.
The clutch washer is quite thin, but for sure it makes the difference between being clearanced and not.
OK, so what does this have to do with the bearing? If you push the bearing up against the oiler, and then leave only .033" gap between the lobe and the case boss, the crank is not fully seated in the bearing. ... making it definitely impossible to have enough clearance at the end of the crank, to accommodate an e clip.
I'll take some photos, but I gotta find someone else that can confirm this.... anyone got a 440 kit sitting around?
