- 7:38 AM
- Dec 3, 2015
- Banner Springs Tennessee
Ima call you later
Bring it on.
Ima call you later
I have a steel plate that I clamp in the vice.......then I slide the crank on it with the steel plate in between the counterweights. So that the stub is sticking straight up in the air. That supports the crank so it can't get knocked outta wack....
Then I drive the bearing on using a piece of pipe that fits on the inner race. (on bearings with steel cages I heat a plate of steel and lay the bearing on it to get hot) No chance of damaging the crank or the bearing this way. Once both bearings are seated on the crank, I heat the case half and slide in the crank. Some saws use the oil pump as a positive stop, others bottom out on the flywheel side bearing pocket.
I have a spare busted oiler that I use for that purpose (044/440).Randy,
Hope you take this question out of my own ignorance...Ive been questioning the "heat" side of heating a case for bearing removal/replacement and have read the Stihl manuals several times where they state to heat the case to 250* with the oiler ON. Same oiler that came off and you intend to use. so my question is does 250* plus or minus 25* do any damage to anything at all ? (Assuming no rubber or gaskets are present ?)
I don't believe so.
Randy,
I don't believe so.
The clutch side seal is possibly the biggest pita on these saws. The seal goes in the oil pump first, and then you have to slide the whole thing on, and there's a lip in the crank. Lotsa grease and film strip or pop can aluminum to make a ramp to get the seal over it. 1st time sucks. 5th time is easy
So what side of the oiler does the seal get installed?
Obviously I know in which direction it faces.
But the gear is sorta in the way.
Without disassembling the oiler, this is the only way I see to do it.I've been pushing them in backwards on the 2 series, seems to go OK, just get the depth the same.
Usually when the paint starts to blister.....when i put the pumps on i cut the clear window plastic out of a stihl chain box and wrap it around the crank.
and when installing bearings i go somewhere around 325f.after watching one of tree monkeys videos i threw the thermometer in the corner.
exactly.when it starts smelling bbq'ish its ready.that is usually just before the magnesium underneath starts turning a really bright firey color.Usually when the paint starts to blister.....![]()
PerzactlyLol The residual oil will start to smoke, then it's hot enough. I quit using the thermometer after I figured this out.
