Saw video thread
malk315
Running Saws for Therapy
11:05 PM
Lancaster, MA
Did you build this one for you Al? Looks like some major power increase w/ your magic worked on it.
Is that an mtronic? I'm assuming since I didn't catch you messing w/ needles in the vid.
Seems like she wants to idle too high at the end of the 2nd vid -- hope it's not a sign of air leak or the like.
Still love it! Hope you are well and Happy New Year!
11:05 PM
Its not a leak. Not sure if the MT is still learning. Could be my mix.
11:05 PM
What mix are you running Al? I've heard that some of the computer saws don't like some oils at over 40:1, but if it worked with it before it was ported, then I think it should work just as well after porting.
11:05 PM
Just watched @Redbull661 vid on the reset. I let off the throttle after a second or two at high rpm, not after it dropped rpm. Probably part of my issue.
A ported saw can certainly be more affected by a mix than a stock one Mike. The compression makes them run hotter and the MT will have difficulty fattening them up with a very viscous mix. I’m at the end of my Motul800 gallon now.
