Saw video thread
8:30 PM
I cut all day today using Stihl 026 MOFO Worksaw and JMSSAWS 440. 70 degrees and sunny today.
I was using VP fuel with Red Armor at about 36:1.
Both saws ran real strong.
This video duo is comparing .325 and 3/8 Full Chisel chains on 18" bars in the same piece of wood with 7 pin rim sprockets. Both chains were hand filed prior to use by me. Both chains are fairly new.
First video is 026 running .325 chain.
Second video is 026 running 3/8 chain. Full Chisel, not pico.
Overall, the .325 seemed better to me. Smoother in the cut and held higher RPM'S. The 3/8 chain really grabbed the wood and loaded the saw much more than the .325 chain.
The 3/8 was 2 seconds faster through the log.
I wonder what woulda happened if you fattened the saw up a bit more. May have had more torque.
18" 3/8 RS is a lot for a 49cc saw, no matter how well it's built.
Darin
JACK KNOB PRICK
5:30 PM
DUNSMANURE, CALIFORNIA
Take a bit more meat off your cutters and leave your rakers where they're at on your 3/8 and will cause less pull/drag and also kick your rpms back up. Should cut faster and smoother.
Cigmaker
8:30 PM
va
This is some burr oak that's been sittin by the shed for about 4 years. It's pretty dang hard
Know it's hard when you get past the part that had been cut with a saw already and the sound doesn't change. Looking good :clap:
