hseII
Heef
- 3:46 PM
- Dec 29, 2015
- West Georgia
Oilers like a 394 or 9010 keep the sap at bay a little better.
Slobbering, Leaking Gals, they are.
That they are. Those usually don't leak a whole tank out sitting on the shelf.
You seem to really like 70cc stihls Mike, you might as well get a ported hybrid too
I usually run full skip on 32" and above regardless of the power head
Compare it with the tip buried trying to clear chips before you decide to stick with full comp on the longer bars. I've used 130dl of full comp and as long as the tip was exposed it's fine. Bury the tip and the chips have no where to go but into the kerf and chain.
I have bucked stuff a 50" wouldn't clear. It sucks to get that much bar and chain bound up with chipsAgree totally, that is why I like to use the 28 or 36" bars for felling, keeps me out of "chain bind" trouble.
Im goin down to Randy's for sure, not so sure if I'll make it to Dans......sure would like to though
That don't work on trees 50-60" though unless you climb on top.When I have to buck something longer than my bar, I usually go over the top and down the backside first, which usually keeps me out of "chain bind" trouble! (The trunk was a little bigger near the bottom)
