Saw video thread
malk315
Running Saws for Therapy
12:02 PM
Lancaster, MA
Here is 044#1, an un ported 044 with 28" B&C running RSL (right off the reel) in 19" Oak. Not bad for a un ported saw!
Saw sounds bad azz... some prefer music, I prefer 2 cycle with unrestrictive muffler ... its ok if "normal" people call me nuts.
Is that with huztl muffler? Must be. I want to hear it live... video does muff modded saws no justice.
Taking the 044 to a tree job tomorrow so bro can try it. Still waiting for huztl from China. Microburst in Haverhill Monday dropped a willow on a house.
Also have a crane job coming up monster tree another willow... junk wood...
Sent from my XT1080 using Tapatalk
paragonbuilder
12:02 PM
Norwich, CT
I'm very pleased with the way the MS-440 runs, however, I think 044#1 is just a freak of nature or something.
In the same wood, with the same mods, 044#1 is about 2 seconds faster.
My buddy has a 460 like that. It runs with ported ones and its bone stock. Not even a muffler mod. It's a head scratcher.
12:02 PM
I have heard some builders say that virtually every saws comes through with different port timing. Often it does not make much difference, but every now & then you get lucky. It was always a strong running saw, but it seems to have really taken to the "at home mods" including the base gasket delete and timing advance.
jmssaws
Banneded
11:02 AM
A good 046 cylinder would probably run close to a mild ported bad 460 cylinder.
There not as bad as the 1122 cylinders but a good cylinder stock will make a better ported cylinder.
A good timed stock cylinder will be stronger generally as a poor timed cylinder ground to the same numbers.
In a 1122 stock timing plays a major role in how well it runs ported.
That's why there's very strong and very poor running stock stihls.
12:02 PM
how can you tell a 046 cylinder apart from a 460 cylinder ?
jmssaws
Banneded
11:02 AM
Better timing and some have a d chamber but it's not necessary.
046 and a 460 run different but nor like there bigger brother.
My first year 046 was noticeably stronger than my 460 stock.
My 460 is stronger ported but it's taken farther.
12:02 PM
i have a 046 that runs good not sure what cylinder is on it i bought the cylinder from old cat from the other site i run a 8 pin sprocket and is quick ill take it aprt tomorrow and take some pics of it
12:02 PM
My experience has been that most 046s don't run much different than 460s, the exception being the 1st year 046-D jugs.
My 046 would not out cut my 044 till I got it ported, IMO, porting makes a big difference on those saws. (at the time both saws had dp muff cover and HD-2 filter, but had not done the timing advance or gasket delete to either saw).
I'm not sure how much difference a gasket delete would make on an 046 or 460, but my 044 and 440 have really responded to it.
Both my ported 460s have 046-D jugs, and I think they are even just a hair stronger. I hear the D jug results in about an extra 10 psi, plus I think (in general) they came with better stock port timing.
