Saw video thread
Slumberjack
Team OPE benchwarmer
12:36 PM
Way down south Louisiana
No, I just widened it.
Good. I got one I’m machining here that came on a saw I bought I had to take .050” out of the squish band just to get the exhaust to 105 which ain’t that great. I’ll have to put it on a 350 riser and take total of .047” off the riser since you can’t take that much from the base. Good move not raising it. Good strong 346 should be lower on the exhaust
Slumberjack
12:36 PM
Down where? Unless you are in Alaska I'm north of ya...
Not sure what you mean by once every thousand years snow? If anything this is a low snow year.
Not looking for sympathy, 40 below has been a normal winter thing for the last 19 years. I've had that hat for 18 of them... Lol
See I think he thought you were me because I just built a saw like yours and ported it lol I’m in the coastal region of LA.
stihl_head1982
Here long time
1:36 PM
USA
Not talking to you sir. Thanks for answering though. It makes perfect sense.
Slumberjack
12:36 PM
Now that we’re all caught up. Lol I’m about to burn some wood I’ve already cut because we have no power or running water from the once every 1000 year freeze we have going on lol
Slumberjack
12:36 PM
No thread on this one. Grabbed a bunch of parts off the shelf on a Sunday night before night shift and fired it together. Might have to put one together. Hyway Nikasil popup kit, ported, late 266 carb, top cover is some aftermarket junk that didn't fit the 272 I bought it for...
The 266/272 I just built I machined and ported all OEM except the meteor piston.
Ronie
1:36 PM
NC
Good. I got one I’m machining here that came on a saw I bought I had to take .050” out of the squish band just to get the exhaust to 105 which ain’t that great. I’ll have to put it on a 350 riser and take total of .047” off the riser since you can’t take that much from the base. Good move not raising it. Good strong 346 should be 107-108 exhaust
This one was 106, measured with a ring and without the gasket.
davidwyby
Rural desert logging
10:36 AM
Extreme Southeast CA
@Ronie @huskihl noice!
stoked on this pretty @blsnelling 2252 that just arrived from @chipper1
Good old dry hard Euc. I have since put it in green tamarix and it's quick. Ordering a rim to go 3/8".
Gonna go back out and make a cut with the ole 2050
and compare.
@cuinrearview thanks for the 50cc push
