Saw video thread
9:26 PM
I don't think so Mike. We specifically ran 460s only until the free for all began.
I was never aware of any saws but 460s.
We need to specify the same rim sprocket next time too. Lol
9:26 PM
Jeff, look at all the Hybrids that were also included. You can also check with Mason, because he specifically asked about the other saws.
Sorry Jeff, you are wrong on this one!
9:26 PM
OK, I went back and looked … started out as 460s, then expanded to include Hybrids and other saws of similar size.
9:26 PM
We ran all 460s first, then it turned into a free for all.
In order to be fair. You can really only test run 1 saw size at a time. We specifically wanted to test 460s. 461 is close but different animal. Same bar and chain takes out variables and really concentrates on the saws strengths.
Wolverine
dilligaf
9:26 PM
I appealed my channel deletion last night on the computer ...I finally found a way to appeal without my channel url ...which was deleted ....they rereviewed and cut it back on last night ....Porcine channels matter ...lol
Sent from a pigs azz...
Did they give you any reason it was nixed in the first place?
9:26 PM
We have to redo the 460s at Dan's and use same size rim.
Your run has been disqualified due to running 7 pin when we all ran 8 pins.
We can redo.
9:26 PM
Jeff, we should just run any size saw with the same B+C in a nice piece of hardwood (not my fault that you guys did not know how to set up for hardwood) and sort by ccs and ported/or not after.
I think my 044 will do well in the "non ported" 70 cc class, and my Flying Tiger 660 will do well in the "Asian Unlimited" class! I wish I had it running like this before Randy's Asian 660 run off, would love to see how well it would have done in that!
I can bring the same B+C (new chain). It is a 24" wide nose .063 running off the roll RSL. I'm sure I still have a fresh loop or two.
9:26 PM
Even with cutting out with the hybrid on the first cut, the 460 was consistently a tick faster in hard red oak. I was pushing on both saws and cutting with them where they felt like they ran best. We did this same hybrid vs the same 460 above in white pine and the hybrid took the crown. In hardwood the torque difference is most definitely noticeable, the 460 has more. Pine... not as much. Results of course may vary depending on the individual saw and who modified it...
