Saw video thread
paragonbuilder
3:06 AM
Norwich, CT
I am with you Mike. .325 7 pin I think does fine fir my liking. 3/8 really makes the saw work hard, and doesn't seem to cut that much faster.
I don't disagree Jeff. But I think you can load the saw more with the .325 and gain cutting speed.
RI Chevy
3:06 AM
earth
I guess I will take 2 more off the rakers again tomorrow.
Which chain/rim sprocket combination did you think worked best Dan?
RI Chevy
3:06 AM
earth
I just timed my cuts. They were all pretty close. The 3/8 was about 1 second or .75 seconds faster per cut. To me, that doesn't seem extremely significant. The 3/8 grabs hard, and I noticed a little more spooge on the exhaust. Maybe I should have leaned the tune a little. The .325 flys through the cut. For me, the .325 7 pin seems to work best for the 026. I don't know, maybe I am just getting old.
I work alone, so for me, a good safe smooth cutting chain works. I sharpen chain every other tank. I do it religiously, regardless of what size chain I use.
paragonbuilder
3:06 AM
Norwich, CT
If you switch to square filed, or at least take your rakers down more, the 325 can work very well. And you can work less hard, let the saw work.
sawmikaze
3:06 AM
steeltown
.325 is smoother but 3/8 lasts longer
Ive tested that theory with saws at work and didnt find that to be true at all..naturally 3/8 carries a bigger tooth and takes a blow better but .325 has more cutters for a given bar length.. its a wash...and if there is a difference its not significant enough for a hobbyist to even care...i run .325 on every 50cc saw i have/had because i like how smooth it is.
Deets066
AKA Deetsey
3:06 AM
Here it is:
https://scontent.slackerc1-2.fna.fbcdn.net/v/t1.0-9/17190540_1295487327199572_3980595491757302740_n.jpg?oh=70ce45ae327095fdfc0afbed12b1f0b3&oe=5965FDCE
https://scontent.slackerc1-2.fna.fbcdn.net/v/t1.0-9/17308860_1295487373866234_5275537590164505145_n.jpg?oh=b06ae5a523d5a3e0cec7312254351bb0&oe=595413E3
https://scontent.slackerc1-2.fna.fbcdn.net/v/t1.0-9/17203243_1295487417199563_4531835409745317588_n.jpg?oh=cc597ecc3bdd7436068378f340783e05&oe=596883B1
I like mine better
