PA Dan
FYD
- 8:56 AM
- Dec 28, 2015
- White Oak PA
Yep thats the plan to richen up the L a little.Probably just lean on the low side?
When they're lopey like that coming out if the cut and they're hot, its usually a good indicator the low jet is too lean. I sometimes also forget how important the tune is when they come to temp. I have a 2166 I am enjoying from a friend that, when it's real cold like its been, is super fat when I start out. By the time its hot and up to working temp it is just about right. I should really get video of it too.Nice Dan. What's with the wonky idle at the end?
I see the go-fast bar on the saw.
Holy hell the torque that sombitch has!
It started at a joke with Tim and Brad. It was their idea. but that *s-word is funny. I’ll just go with it pahahhahaHey Baw I see CoonAssWorkSaws is sticking.
As long as folks read my signature and see that I’m not taking port work. Leave that to prosHey Baw I see CoonAssWorkSaws is sticking.
I just have a few that I’m good at. Those guys turn everything into Tasmanian devils. The saws I’ve ported and fugged up far out weigh the ones I do well on.As long as folks read my signature and see that I’m not taking port work. Leave that to pros
Revision 2 coming soon lolLooking good from here.
Little of both but focused on torque. It’s a strato so the piston is heavy and they don’t like too many rpm’s. It’ll do great with a 20” and 8 tooth rimNice Kevin. Was this ported for torque, speed, or in-between?
How do you port for torque or speed? I know guys have lots of different ways of getting what they want...Little of both but focused on torque. It’s a strato so the piston is heavy and they don’t like too many rpm’s. It’ll do great with a 20” and 8 tooth rim
Don’t widen the exhaust quite as much and leave it low. The upper transfers still have plating on the intake halfHow do you port for torque or speed? I know guys have lots of different ways of getting what they want...
