Saw builds
9:52 PM
Are timber here is very valuable because it grows very slow so it has small growth rings but that also makes it very hard,the pig nut and shag bark are hard to cut down because they kill your chain and that's why nobody cuts them.
Got a lot of walnut in your area?
smokey7
9:52 PM
Detroit
@jmssaws I suppose that 361 must have exhaust side ring ends? Those transfers are huge
jmssaws
Banneded
8:52 PM
I have worked most of the day trying to find out what was wrong with this 361,it was In peices and I didn't try it before I ported it.
I've never ported one or ran one but I knew it was off and I finally found it.
This is a first for me.
redlinefever
8:52 PM
Iowa
Almost looks like a crack from there to the intake??
jmssaws
Banneded
8:52 PM
It's a hole in the casting.
Barely leaks and I'm sure nobody ever noticed it.
It ran ok and tuned and idled good but it was blah and shouldn't be and once in a while it would run away at wfo.
Failed vacuum test bad but had to air it up in a bucket of water to find it.
X 66 stang347 X
9:52 PM
Georgia
I've seen a few crazy stuff on a new saw. Some showed up right off the bat on a new start up and some didn't.
One was a ms251 with no piston ring pins. Customer ran it for about 15 min before it caught a port.
