Remington
Pioneer
Old Saw
12:23 PM
Kamloops BC Canada
heimannm
2:23 PM
Dike, Iowa
I am in need of a flywheel cover and starter for a Super 754. Lots of non Remington stuff as trading stock or plain old cash...
Mark
ChipsFlyin
OPE Platinum Member
3:23 PM
Pittsburgh
The darn carb was so varnished that everything was clogged and stuck. Soaked it in gas for a few days. It helped some but not near what was needed. I will try an AM 070/090 carb for now. If it doesn't work I will get the old carb to my friends sonic cleaner and rebuild.
67L36Driver
2:23 PM
I got the $13 aftermarket 070/090 to work!
Good job. [emoji108]
I liked how my Clinton turned out with the 070/090 carb I bought an extra.
It may end up on the Super 990. [emoji1696]
ChipsFlyin
OPE Platinum Member
3:23 PM
Pittsburgh
Little trick that I did with the choke level. 1st the level was easy free to drop close. 2nd the screws were a tad long the holds the air filter housing in place and would bottom out on the choke shaft. Used a small lock washer on the head of the screw to prevent bottoming out. Then, cut a real small piece of fuel line, 2 mm x 2 mm only one wall thickness and placed it in the thread socket up against the shaft. Now there's a soft tension when tightened down on the choke shaft so does not flip around.
67L36Driver
2:23 PM
I drilled the screw hole deeper for the spring & ball detent from the original carb.
edju1958
3:23 PM
Western N.Y.
Hi guys,I got another SL9 in the mail today.The seller must've gotten the recoils mixed up with another model like a Mighty Mite.The recoil he sent me is WAY too small.Does anyone out there have a complete recoil assembly that they'd be willing to sell?It doesn't need to have the switch,that's still on the saw except for the plate & nut.
Ed
edju1958
3:23 PM
Western N.Y.
I've got 2 SL9A's & the auto oilers don't work on either saw.I need to know if the saw must be running in order for the manual oiler to work.
Ed
edju1958
3:23 PM
Western N.Y.
Wow! I can't believe that I was the last person to post here almost 6 months ago.I guess not a l.
Edot of people have Remington saws.Anyway,I'm looking for a set of bar plates for an SL-9
edju1958
3:23 PM
Western N.Y.
Hi gang,haven't been here in a while,but been working on those Remingtons! I picked up this "Agway special" last week & it was in rough shape - no spark to start with.I pulled the points out & found they were burnt pretty bad.I cleaned them up with emery cloth & put them back in along with a known good condenser.I then had spark again,so it was on to the carburetion.I think I must've primed it at least 15 times before it finally started running on it's own.Today I put an 18 bar & chain on it instead of the puny little 16 in.that came with it.I wanted to put a 20 in.on it,but the bar studs were 3/8 & the bar slot was 5/16.
countryhog
BTDT
2:23 PM
NW Arkansas
View attachment 266876 View attachment 266877 View attachment 266878
Take a file after the bar slot. Done some that way; works great if the oil holes will work
Saw Collector
OPE Member
3:23 PM
Here
Hey fellas. Thought Id share this little project.
Three to make one or two. Best parts of all three are on the one in the video. Its a mix of bantam and deluxe parts. I'll paint it later.
Does anyone have a good coil for a mighty might bantam they would sell?
https://www.dropbox.com/s/n2v9dgb27dssm52/VID_20201202_121432440.mp4?dl=0
Click continue to website if you don't have the Dropbox app. Great running saw.
