Rebuilding And Porting An 084
Brewz
2:36 AM
Hunter Valley - Australia
Well ok.........back to the damn 084. lol
Timing numbers after machine work. Hey @Brewz .....
Ex: 99
Tr: 124
In: 71
Took .030" outta the squish, and .038" off the base.
Clearance is .023"
I have found 99/121/74 to work great with massive power and a wide power band.
I have tried them with the intake down further at 79 or 80 and they are more violent and peaky.
I usually slightly widen the exhaust and flatten the roof a bit to take advantage of the raised uppers, widen the transfer tunnel towards the exhaust port some and open the uppers flat.
A red97 port on the flywheel side with a 3/4" hole under it and the factory outlet elongated all the way along
They tow like a freight chain at 12500 RPM running an unlimited coil
11:36 AM
So......for a dedicated milling saw. 99/121/74 ?
There is a slight lip in the intake. I'll knock it off and see where it lands.
Brewz
2:36 AM
I have one at 99.5/124/73 with stock uppers.
Its strong but feels half ported.
I built one for someone who wanted usable torque for big hard timber and milling. He didn't want a difficult screaming monster.
I took it to 99/121/74 and it was a torque monster and he loves it.
I have another 084 I messed with opening everything up more and took it to 99/122/80 from memory and its a screaming monster that opens your eyes with a 25" bar in softer timber but is all or nothing with a longer bar.
Brewz
2:36 AM
Pictures are of the saw I built to be usable.
Here it us in use cutting 11000 Jenka hardness dry Eucalyptus with full chisel, full comp 404 and an 8 tooth sprocket.
I was getting tired by this stage, had tested about 8 saws and cut up the entire tree in 35*C heat and tropical humidity.
I stopped after this run
11:36 AM
Yeah, I can see 124 being too low on the uppers. I've gone as high as 118 on em, brutal, but peaky.
12:36 PM
Nice job Brewz. [emoji106]
Your 2nd video looked like some shag bark may have been jamming the sprocket a bit.
But nice strong saw there.
Brewz
2:36 AM
This is my half ported 084 with a 36" bar, 404 full chisel full comp and 8 tooth in dry dead rock hard eucalyptus
Its at 99.5/124/73 from memory and I lowered the intake down from about 69*
All 3 saws have about .020 to .030 from the band and blow around 170 psi cold
Brewz
2:36 AM
I ported that saw above before I had a 90* tool and I plan to go back in and touch it up to 100/122/74
My call is 22ish blowdown with a flatter exhaust roof, and dont go too low on the intake as they seem to like plenty of case compression for running a long bar.
I have spoken to some racing guys here in Aus and they have said they will run great with a lower exhaust and they do, but its more of a shot bar race setup from what I have found
11:36 AM
I'm gonna leave the exhaust port stock. It has a lovely shape, and beautiful bevels. Normally I would widen, and reshape it, but this saw will live on a mill, and I want the rings to live a long happy life.
Sleeper
12:36 PM
United States
Beaver lube and solvents company is about 1 hour from where I live. Their "Bolt Buster" for breaking rusted stuff loose is better than PB Blaster. No bull.
