tree monkey
- 11:36 AM
- Dec 14, 2015
- wi
300.00 plus a new clutch from jms.
better get more then a lap dance for that.
hows about a jms cylinder?
hell no use that crap for a paper weight.better get more then a lap dance for that.
The YUGE intake port. I really wanna add a few degrees of duration.......so I might trim the piston skirt a wee bit. At 71°it seems pretty short.
Well ok.........back to the damn 084. lol
Timing numbers after machine work. Hey @Brewz .....
Ex: 99
Tr: 124
In: 71
Took .030" outta the squish, and .038" off the base.
Clearance is .023"
I have found 99/121/74 to work great with massive power and a wide power band.
I have tried them with the intake down further at 79 or 80 and they are more violent and peaky.
I usually slightly widen the exhaust and flatten the roof a bit to take advantage of the raised uppers, widen the transfer tunnel towards the exhaust port some and open the uppers flat.
A red97 port on the flywheel side with a 3/4" hole under it and the factory outlet elongated all the way along
They tow like a freight chain at 12500 RPM running an unlimited coil
I have one at 99.5/124/73 with stock uppers.
Its strong but feels half ported.
I built one for someone who wanted usable torque for big hard timber and milling. He didn't want a difficult screaming monster.
I took it to 99/121/74 and it was a torque monster and he loves it.
I have another 084 I messed with opening everything up more and took it to 99/122/80 from memory and its a screaming monster that opens your eyes with a 25" bar in softer timber but is all or nothing with a longer bar.
I ported that saw above before I had a 90* tool and I plan to go back in and touch it up to 100/122/74
My call is 22ish blowdown with a flatter exhaust roof, and dont go too low on the intake as they seem to like plenty of case compression for running a long bar.
I have spoken to some racing guys here in Aus and they have said they will run great with a lower exhaust and they do, but its more of a shot bar race setup from what I have found
