Project 660
jmssaws
Banneded
7:11 PM
Why did it cut my pregnant belly off?
Square filed chain again?
psuiewalsh
Basement Bodging
8:11 PM
Nottingham,pa
I need to put the new used piston in and see what the squish is with this cylinder. I then need to see if it is under .020, if so I was thinking of sanding the cylinder to get to .020. I have not cut a cylinder before. I have access to a lathe but it only has a 3 jaw chuck so I guess cutting the base would be doable but would need a mandrel to do inside the cylinder. I want to file the key .020 also since this seems to be recommended.
What would you think next steps?
jmssaws
Banneded
7:11 PM
Squish can be 030 but I've seen them 017.
You have a gasket in correct
psuiewalsh
Basement Bodging
8:11 PM
Nottingham,pa
Haven't installed the piston yet. Will try for tomorrow sometime depending on the family's needs
jmssaws
Banneded
7:11 PM
If it's 030 sand 010 off the base.
You can find different thickness of gaskets but there rare. I've probably got 50 gaskets and all but 5 are 017 but the few are 010. All steel. The paper early 066 gasket is 030.
8:11 PM
I'm going to guess squish will be .028" with a gasket.
That 365 is fast and the 357 was fun to trim the edges for the mill to clear.
Stihl working Hard
Is it Friday yet
9:11 AM
Perth Australia
660 FTW
That's a nice log:headbang:
