- 7:53 AM
- Jan 8, 2016
- Farmington, CT
I can understand if debris is in the pocket, and then the bearing is ...canted. if there is ANY cant at all to the bearing, there will be drag on the bearing. I get that. during a production process you might not catch that in quality control...
seems like a diyer would catch it if there is so much drag as to ruin a bearing. ...even if its cold pressed.
also. ...those bearings don't have sharp edges on them. the edge on the outer bearing race is round. assuming the magnesium chassis is also smooth enough, what would create the shavings?
