Poulan Pro5020 starter assist spring keeps bending
jjgolec
New OPE Member
2:43 PM
Pa.
Running Poulan Pro 5020 when starter rope broke. Changed rope, but now the assist spring keeps bending. pics included might explain it better. With spark plug out works great With compression of spark plug in, is when it bends. What am I doing wrong?? Please Help!!IMG_0331.JPG IMG_0332.JPG
e.fisher26
2:43 PM
Ma, USA
Usually your just pulling to hard, see if you can get the non easy pull recoil for it
jjgolec
New OPE Member
2:43 PM
Pa.
Any suggestions on where to get the non esy pull recoil?
e.fisher26
2:43 PM
Ma, USA
Pic of the outside of recoil?
e.fisher26
2:43 PM
Ma, USA
Crap, I didn’t realize it was the newer design, I don’t know if there’s a non easy opt. Can either buy the new spring for $2 on jacks site. Or epoxy the 2 pulleys together.
smokey7
2:43 PM
Detroit
Are you pulling it like a normal saw?? Or are you slowly pulling the rope and then letting the spring unload on the engine?
jjgolec
New OPE Member
2:43 PM
Pa.
Like a regular saw . Not any harder than normal.
kneedeepinsaws
12:43 PM
Oil Country
Your new rope is it the same length? You might be over tensioning the spring pulling on the starter to far?
i can attest that the “pullin pro” series of saws usually have very very robust starting mechanisms ;)
jjgolec
New OPE Member
2:43 PM
Pa.
Cord is same length as the one that came off I did notice the screw holding the starting mechanism keeps tightening up when spring distorts!!
smokey7
2:43 PM
Detroit
These easy start engines I've seen require a different starting procedure. You must pull slowly then let the Spring release its energy on the engine when its ready. Pulling it like a regular engine will cause this every time.
jjgolec
New OPE Member
2:43 PM
Pa.
Will try that!!!
Yukon Stihl
11:43 AM
Great White North
Used a saw with start assist this year to make sure i fixed it...
It's broke again,probably because i used it like a real saw.
It is getting a real recoil.30 something cc saw with start assist ...phss
jjgolec
New OPE Member
2:43 PM
Pa.
Tried pulling cord easy bent the 10"th spring Yea 10 springs ruined, trying everything? Just dont know where to go from here.
e.fisher26
2:43 PM
Ma, USA
Find the poulan forum, someone may know more.
jjgolec
New OPE Member
2:43 PM
Pa.
Is there a regular recoil?
Do you need the easy start
Unfotunately it looks like that is the only way it will work Trying to remove assist spring and put in a solid pin. I used a small rod I had but it bent. I will have to look for some case hardened steel to use instead. Open for any suggestions.!!!
