HUSQVARNA Post your favorite 2series Husky.
rattler
11:25 PM
NC
It's finally getting a 266 top end, seals, lines and a rim drive setup
I got hold of a white top had a 162 top-end on it the guy had put the piston in backwards so had to fix that but it was a strong saw for sure
Sent from my SM-G935V using Tapatalk
DSS
widebody
12:25 AM
canuckistan
I got this one mostly back together, I didn't put the gauge on it yet but I can hardly pull the damn string. Had .026 squish. Might be snappy when I get it running.
rattler
11:25 PM
NC
I would guess it will be very strong I like that combo right their they did you put the big carb on it?
Tor R
Novice, Leg model #2
4:25 AM
Mandal
Bumping up this cute thread ;)
Bought it on ebay, for some odd reasons I had those black fuel & oil caps. I'll probleby take her apart later and get her repainted...
Another one I bought on ebay (1996 model)
Those xpg wires is famous for issues, this is how I choose to protect them:
While I was in the mood for some 242's, I bought a future project in Norway, not the smartest I've done
And this one is on the way...another impulsive purchase lol
Simondo
3:25 AM
UK
Tor...those black caps and that grooved black plastic cover on the 242 hoop handle ...only seen that on a 154 se i had ??
Tor R
4:25 AM
Mandal
242 and 254 used black plastic/front handle bar rubber until 90 or so, Simon
42 used grey plastic/front handle bar rubber the whole time, even on their Anniversary who they started to produce in 1988 was in grey.
A100HVA
11:25 PM
CENTER CONWAY,N.H.
here's my first try at a complete restoration,it's a 266 SG. i had the cylinder stripped,NiCom,honed by u.s. chrome.new oem piston,crank & bearings,ignition,carb,air filter & top cover,recoil housing & chain brake,generator,front handle,rear grips.
only modification was base gasket delete,larger 3-shoe clutch.
INTERNET POST PIC NO.462 Large Web view.jpg INTERNET POST PIC NO.463 Large Web view.jpg
my second try was this brand new crankcase & flywheel for 154/254 i found in my parts drawer that's around 85 or 87. i had enough NOS to make it into a 262,only modification was muff mod & base gasket made of writing paper INTERNET POST PIC NO.460 Large Web view.jpg INTERNET POST PIC NO.461 Large Web view.jpg
Tor R
4:25 AM
Mandal
View attachment 68548 View attachment 68549
my second try was this brand new crankcase & flywheel for 154/254 i found in my parts drawer that's around 85 or 87. i had enough NOS to make it into a 262,only modification was muff mod & base gasket made of writing paper View attachment 68550 View attachment 68551
nice builds,
Its William, right.
looking great, but bud, how come this saw is'nt a runner by now? :D:D:D:D:D
I wish we had decent powder coat guys in Norway :(:(
jake wells
no longer here
10:25 PM
ky
stihl fs 80 tank grommet and regular fuel line will get you away from the pre molded line which is 10.99 oem
the tank grommet with line is around 2-3$
  • Like
Reactions: DSS
A100HVA
11:25 PM
CENTER CONWAY,N.H.
yes Tor R, it's william.
now that i got started painting,and restoring i found this nice condition 140S in the pile of saws that i cleaned up. it's next to get "the treatment"
i figure it sat in the pile for about 25 years. i looked in the spark plug hole and saw that the cylinder wall by exhaust port was nice and shiny,so i filled it up with gas and tried to get'er going.it had tremendous compression!!...only to find that bar oil had leaked into crankcase.when it did start,wow what a smoke show!!...when it quit smoking,it re-started real good.so i put the tach on it...14,000+-.the guy that gave it to me said"i never could get this saw to start good" i believe it had a bad center gasket right from the get go.2017-05-12_08-46-38_194.jpg 2017-05-12_08-46-15_296.jpg
here's the finished 266SG
Tor R
4:25 AM
Mandal
Bumping up this thread again.
I've been reading service bulletins (to bad I dont have them all) this weekend, and here is maybe some information your guys may like to know ;)
266:
New crank and clutch (1/2" UNC to M10×1-V
266 SE s/n 6024957
266 SG s/n 6080640
61 s/n 6051313
HS 224 carb:
266 SE s/n 5312370
266 SG s/n 5160935
254:
New starting house and XP/XPG was introduced:
S/n 0150175
Conrod bearing went from 14mm to 15 mm:
S/n 3360001
Oil pump prepared for the new oil worm gear:
S/n 3450001
262:
S/n 3359195
S/n 3450001
42/242:
Conrod bearing went from 12mm to 13mm:
42 s/n 4110291
242 xp s/n 4130001
242 xpg s/n 4110001
Sty57
10:25 PM
Land of Cheese & Beer
266:
266 SE s/n 6024957
266 SG s/n 6080640
61 s/n 6051313
HS 224 carb:
266 SE s/n 5312370
266 SG s/n 5160935
254:
S/n 0150175
S/n 3360001
S/n 3450001
262:
S/n 3359195
S/n 3450001
42/242:
42 s/n 4110291
242 xp s/n 4130001
242 xpg s/n 4110001
Lots if good stuff in them bulletins. But it's a pain to sort them out.
