Redfin
Meh...
- 3:27 PM
- Dec 24, 2015
- Central Pa
And hogging out lowers without regard to direction will not help the cause.
I personally haven’t seen much benefit from them. Imo a well done transfer port doesn’t need them. Of course there is always an exceptionIMO, transfers are the most "confusing" port.
So, for those of us who like to tinker, but do not have all the fancy tools, what is your take on Bridge Ports?
IMO, they can increase flow a bit, and more importantly, direct it where it belongs.
Mike... you can not un *f-word bad port timing.I won't dispute that at all Mike, but my question was, if you don't have the fancy tools to do the transfers correctly, can bridge ports be a substitute?
Are you sure?....And hogging out lowers without regard to direction will not help the cause.
Go read my post again.Not talking about changing timing Kenny, just the direction of the transfer flow. I believe bridge ports can make a positive difference.
This is just my opinion (and I could very well be wrong) but in my mind, if bridge ports help, your transfer tunnels don’t have enough areaIMO, transfers are the most "confusing" port.
Maybe bridge ports could help a lazier or poorly aimed transfer work better if I am understanding it right? But couldn’t that be changed or achieved with the right blowdown?
Chicken *s-word vs chicken?...
Like lemonade vs lemons... not.
The real problem is most of the 660 cylinders (especially AM) having 25-30° of blowdown when they run pretty good with 20. It’s why the early 066 and 046 ran so well having 17-19I was posting as you were posting Kevin. I don't disagree with you, but I don't have a right angle grinder, and getting into the transfer ports is not easy.
I see the Bridge ports as an alternative, especially on poorly ported AM cylinders, but they seem to work effectively on some OEM cylinders also.
Mayhaps you should try it? Let me know how it works out for you.Are you sure?....
Like disMayhaps you should try it? Let me know how it works out for you.
yet.
