ZukiRyder440
Breaker of recoils
- 11:08 PM
- Apr 11, 2018
- NY
Thanks!Looking good buddy!
Not too bad on a 2 port.Looks like the easy side to me, let's see the flywheel side port.
Hell Yes! And... the 600SX was a pia too but came out great with a tiny quench area and almost no volume. Under 1% in the pinchNot too bad on a 2 port.
362, 462, and a 620 Echo are the hardest for me because of the upward angle
In your first pic, see that bottom right corner in the upper transfer port?... make it point at the intake side not that radius round chit you see on most factory jugs and worse on the AM ones. Move that inside wall back and blend it in to the original bevel there at the exit. Don't open the port face or window but open and re direct the port area right before the exit pointUsed a right angle for the first time today. DefiniView attachment 296144 tely something to get used to but its manageable.
Lookin real good lil buddy
Rock it and roll!Thanks. Just got done putting her back together and she runs pretty good
Yuppers. The lower transfers are tiny to start with. I didn’t touch the tunnels just opened up the lowers.
They sure are.Yuppers. The lower transfers are tiny to start with. I didn’t touch the tunnels just opened up the lowers.
Contrary to popular belief, opening lowers and giving more volume adds power across the band.Yuppers. The lower transfers are tiny to start with. I didn’t touch the tunnels just opened up the lowers.
I see alot of people open the lower part of the transfers on old McCulloch saws also but honestly I don't know if I've seen one perform better in the cut then a well tuned one?Yuppers. The lower transfers are tiny to start with. I didn’t touch the tunnels just opened up the lowers.
The only time you want tight transfer tunnels and lowers are when you're shooting for peaky high rpm, that'll narrow the power band. Opening up lowers and adding volume on clamshell is a cheap solution to add tq, since its tough to cut base and all.I see alot of people open the lower part of the transfers on old McCulloch saws also but honestly I don't know if I've seen one perform better in the cut then a well tuned one?
I mean being a clam shell design is a little limiting without being able to lower the jug and add compression.
Correct. Plus it’s aimed hard at the intake wall so it’s difficult to get in there with the 90Transfer roof isn’t flat?
This is a little bit of a blanket statement. If the transfers aren’t big enough to allow enough flow, they act just like a restrictor plate. 372XPW comes to mind. 365 xtorq as well.The only time you want tight transfer tunnels and lowers are when you're shooting for peaky high rpm, that'll narrow the power band. Opening up lowers and adding volume on clamshell is a cheap solution to add tq, since its tough to cut base and all.
Keeping transfers tight is equivalent to using crankstuffers. Good for low load high rpm application
Sent from my INE-LX2r using Tapatalk
