Porting Husky 340/345/350's
isaaccarlson
2:21 PM
Colfax, WI
I have had to buy limited coils for every 350 i have worked on. I have a 345 with an unlimited coil that I might build up just like my 350. I even have a second piston/cylinder to use on it. I have been tempted to put the unlimited coil on my 372....
thedude74
Bonafide & Stuff !!!
1:21 PM
Alaska
I don't like the stock muffler outlet location. I like a pipe in the top right corner that points out over the bar.
i like pipe outlets too. They look nice and direct the gasses away well. Why don't you like the stock outlet? Maybe it has a tendency to melt the brake handle? Might try and retain the spark screen on this one. Solely for the purpose of cutting on public land.
thedude74
1:21 PM
Alaska
Oh yeah. Nothing like a face full of 2 smoke ehh?
thedude74
1:21 PM
Alaska
Got it back together and test fired it. Runs good. Very responsive. No shortage of compression. 😁 Muffler is still stock for the moment. Should have time to finish it up and get a vid soon.
Edit. Also advanced the ignition about 5*
thedude74
1:21 PM
Alaska
Burned through about a tank today in the woodshed cutting and noodling...and just generally farting around. Its definately a completely different saw now. I'll get some cutting action soon.
thedude74
1:21 PM
Alaska
Dropped a couple spruce with the 350. Have a few tanks through it now. Big improvement over stock....but I feel like there's more gains in it to be had. I doesn't help running it against the 361 clone.lol While taking the 350 clutch off I managed loose the clutch bearing....found it under my boot with a broken cage🙄...Waiting on a bearing.... Custom filter mod😂😂20230330_105107.jpggoing to open the muffler up some more and probably add a Zama el42(husky357) carb....and of coarse throw the Meteor piston in it.
2:21 PM
Just finished up with doing a short block.
First to square and flatten the base.
Then get the machining done to the 346xp cylinder.
On to porting.
And what with all the extra joinery going on a pressure test to insure it's buttoned up tight before it goes. Which passed just fine with new bearings and seals.
@nixon
thedude74
1:21 PM
Alaska
