Porting a ms460
8:48 AM
My 046 was 175 stock, when Bret (Smittybilt) got done with it was 205. That saw was lethargic when it went to him, and he woke it up nicely.
My 046-D cylinder was a Mahle (found it on Craigslist, the guy had replaced it with an AM), the one Al likes the porting on is a no-name.
X 66 stang347 X
8:48 AM
Georgia
A little more compression might help
Does it seem a little low? I was expecting maybe about 185. The rings and cly looked good. Had a little wear but the cross hatch was still a little visible. I'll check with another gauge to see if it was off
jmssaws
Banneded
7:48 AM
Sounds right to me
Redfin
Meh...
8:48 AM
Central Pa
Did you replace the rings?
jmssaws
Banneded
7:48 AM
Taking so little off won't gain much and even if the old rings are used it will still need a little run time to seat in.
It doesn't need anymore compression
What's the port timing
X 66 stang347 X
8:48 AM
Georgia
I didn't check the timing. I didn't raise or lower anything. But I plan on learning more about that on my 064 build and maybe go back into the 460 to check and change.
jmssaws
Banneded
7:48 AM
Depends on the cylinder how well it will run
064 cylinders are fairly consistent
X 66 stang347 X
8:48 AM
Georgia
It was scored passed fixing so I put a 660 cylinder on it.And tapped my holes to 6mm w/ Heli-coils.
jmssaws
Banneded
7:48 AM
A 064 cylinder will generally be stronger than a 660 cylinder.
I have a dozen or so 064 cylinders if you want one.
Pm me if you do
jmssaws
Banneded
7:48 AM
This saw adds to my belief that you don't need a high exhaust for rpm,I had it to 15.5 and still 4 stroking good,and it's got numbers I've never used or seen anybody use and has a tiny single outlet with a oem screen.
It's 104.5 125 75
