RI Chevy
- 9:43 PM
- May 7, 2016
- earth
What bar and chain setup is better for ported 50cc work chainsaws?
The age old questions of extra torque vs. higher chain speed.
With ported 50cc work saws, is it better to use a bar and chain setup that utilizes the lower end grunt or the higher speed RPM's for better cutting?
Specifically, 3/8 or .325 bar and chain setups.
I prefer to utilize the higher RPM's that the ported saw makes (Stihl 026) to get a faster chain speed (.325 chain) providing me with a smoother, stable cut. Others prefer to use the lower end power band that the ported saw makes with 3/8 chain. The 3/8" chain generally makes the ported saw work a little harder utilizing lower RPM's during the cut.
Does running a ported saw at slightly higher RPM's good or bad for a worksaw?
Does running a ported saw at slightly lower RPM's provide for a longer life for a work saw?
They both produce fairly equal results, and work well, just wondering what all of you guys use with your ported 50cc saws.
Questions, questions, questions??? LOL
What do you guys think?
