two4spooky
- 6:15 AM
- Dec 22, 2017
- Southeast
Yep, spent too much time living in the truck bedDang that barely looks like it’s been run….. just left out in the weather like a redheaded stepchild.
Good idea. I have one of those camera deals. Not experienced with it though. Not sure if it will fit here. Try to go down the transfer ports? Good ideaPiston looks fine.
I'd be concerned with the amount of water inside if it did anything to the rod and crankshaft bearings?
Would be nice if you had a fiber optic camera to take a peek downstairs inside the cases.
Flushing with some diesel will get the water out, then some mix to coat/oil the bearings
Okay, my fiber optic camera is not a match here, too thick. Poured some two-stroke in, maybe enough oil to mix 5 gallons of pre-mix. Pulled it over and managed to get a face full(plus in my hair & down my shirt) of oil. Yes, I have experience at doing dumb things "Hold my beer" moment. Good thing I can still laugh at myself
Yeah, good advise. Both in regards to oil/alcohol mixing with water and PPE. Too bad I read it after the fact. I knew better when I pulled the rope, just got in a hurry. I will probably tinker with it again later today.
Nice. I like tractors, especially the older ones. I have diesel fuel on hand. Good advise and I appreciate it.For a lot of cleanups I use diesel. Not running any now so keep just a 1-gal fuel can handy. For cleaning a 1-L spray bottle w/adjustable nozzle. Great to get oily stuff off saws after you get the soild stuff scraped off.
I used it last fall to clean up a mess inside a TO-30 Ferguson head that had the oil contaminated due to a blown head gasket. It was a goopy mess of oil mixed with coolant. I Washed everything up top with pushrod holes plugged, then squirted those holes down and out of the oil pan drain, and cleaned the cam/lifters on the way there. Compare before and after.
Diesel works great, it's cheap, but stinks.
View attachment 446219View attachment 446220
