ported 661 baffle in muffler vs baffle out
Coltont
5:00 AM
Pennsylvania
Trooney's saw would stop but it was not as strong when it wasn't popping, reset and it would pop and be strong again.
It's 4 stroking,that's all it can be.
I've changed everything I can change.
Mine popped when I first ran it after it was ported. It doesn't at all now. It's probably had 100 to 175 gallons of fuel through it. I only reset it once since I got it back from porting. Ran it 8 months until I reset it.
jmssaws
Banneded
4:00 AM
Trooney's will stop eventually but it's not as strong.
Reset yours,I bet it needs it
jmssaws
Banneded
4:00 AM
Thanks but no thanks. It runs great, I'm not resetting it. Can't fix whats not broke.
It won't hurt it,it's good to wipe the slate now and then.
I wish I had yours here to compare.
I've done from 95 on the exhaust to 100 and they all run the same.
The 100 saw is just a little more user friendly than the 95 but that's it.
All low compression
Coltont
5:00 AM
Pennsylvania
Couldn't tell you the numbers. Redfin ported it. It's got a pop up timing advance nothing crazy with the muffler, opened up as big as the outlet would allow, course screen, nothing done to the baffle. Ran on what ever oil I have and 87 fuel about 90%of the time.
jmssaws
Banneded
4:00 AM
I know John well,he told me what yours is.
I sent him trooney's and Rodney's so he could try them
Manofstihl066
5:00 AM
Georgia
I've spent several months messing with them and all I know is that there worse cold and if they ain't popping then they ain't running full bore and need reset.
Nothing I have done has made it completely go away,when there the strongest there popping.
Sounds and acts just like 4 stroking to me.
I agree. When u ran trooney's saw with a 32" 404 there was hardly any popping compared to the other vids with shorter bars. Takes a lot to load up that beast.
jmssaws
Banneded
4:00 AM
Yep all you gotta do to make it stop is pull on the handle.
This saw does it morethan the others.
jmssaws
Banneded
4:00 AM
Do you know what is causing it Scott?? It doesn't sound like it's hitting a limiter or 4 stroking to me.
It's odd for sure.
What do you think it is?
It does it just like a 4 stroke, worse cold.
No load wfo is the same sound,lift in the wood it's the same.
Not a single thing I've done made it stop.
I can take power away and make it better but that's it.
Does it with a wj69 also
jmssaws
Banneded
4:00 AM
Is trooneys close to my numbers?
No but this saw is closer to yours.
This one has a lower exhaust than yours but it really doesn't seem to matter,or the 6 cylinders I've been playing with don't care where the exhaust is.
jmssaws
Banneded
4:00 AM
As it warms up and leans out it pretty much stops doing it.
Here's a cold start and cut,bad the first cut but by the 3rd it stops doing it.
Every video of one popping is a cold saw.
I know what it is too,only one thing it can be.
