Ported 350 results
Mattyo
Youtube speciawist
5:05 PM
Farmington, CT
where's 08f150 when you need him...
actually, if you had the stalker gene David, its not hard to figure out who I am, then who my wife is, and then who her sister is...
then again, it may be a little trickier to figure out who MY sister is
and no.... not close
BGE541
2:05 PM
Washington
@Landmark just took a ported 350 out with a freshly sharpened chain to help a buddy from church drop 2 12-16" alders and after tank 5 I'm convinced of afew things... 1. Break in makes a big difference on the few I've done. 2. They really like an open muffler. 3. They like 18-20 BD. 4. They like a full key of ignition advance. 5. I'm not 100% sure I have them figured out but they sure make a fun cutting saw along the way...
Landmark
Chainsaw Hack
5:05 PM
WNC
Thanks for the info. Timing advance is good tip and I will try that too. Sounds to me like you have a pretty good handle on them.
isaaccarlson
4:05 PM
Colfax, WI
Sorry, my wife is an only child. I believe it is a 45mm top end. It measured out at about 44.8mm.
One thing I noticed is how much drag the sprocket and bar add to a saw. With a bare crank and flywheel, this saw was incredibly snappy.
Now that the bar and sprocket are mounted, it is a little more tame. You can tell when the chain is getting dull because the rpm drops in the cut just a tad.
It's a good reminder to carry a file.
idiotwithasaw
4:05 PM
Ky
This is all good reading. I have a 353 that i put a 346 top on. The most aggressive I have gotten, i have the cylinder decked and a popup turned. I have kept mostly stock numbers, and haven't widened anything. It's pretty impressive as it is, but I can't help but wonder what I'm leaving on the table. Maybe I should widen the intake and exhaust. If I had a right angle maybe raise the transfers a tad.
Mattyo
Youtube speciawist
5:05 PM
Farmington, CT
After this weekends 350 challenge....
I think compression increase makes quite a bit of difference, as does a muff mod. So I'm not exactly sure how much you left on the table Ben. I know that a stock saw w/ a muffler mod does pretty good. Brad's saw did best in our tests, and although I don't know what his numbers are, he was running a popup, muff mod w/ no screen.
So, you may not exactly need to go back in. My hyway didn't make the power Brad's did, but I'm not going in to monkey with it, because I'm still happy w/ my result. :)
Tor R
Novice, Leg model #2
11:05 PM
Mandal
Brad's version also run with 357 carb & airfilter system.
Mattyo
Youtube speciawist
5:05 PM
Farmington, CT
Brad just reported yesterday that he installed that jug on his 346xp chassis. he tried it w/ the 357 intake tract, then the 346xp tract... 8% slower cut time. so yes, the intake apparently makes a difference. who knows what that translates to in HP.
paragonbuilder
5:05 PM
Norwich, CT
Like I said before Matt, I think your porting deserves to breathe better! A bigger muffler mod, and maybe the larger carb setup and you may have a different animal!
5:05 PM
Matty,
Your Hyway from last year was pulling 200psi. You said it's down to 160. I can see that making the difference right there.
My comp readings go up, not down, after normal use. I think you need to add a caber to the saw and retest it. Maybe keep a log out and do a before and after time.
That much comp loss just doesn't make sense to me and may be your culprit.
Tor R
11:05 PM
Mandal
if you go this route you may be interested to read through this thread:
http://opeforum.com/threads/how-to-modify-the-zama-el-42.2351/
Also, MM use 346 intake without the ring.
paragonbuilder
5:05 PM
Norwich, CT
Brad sent me a message Matt, he says your saws are starving for fuel at high rpm, and you need to raise your granny's to about 15-16 blowdown...
He says you will see a big improvement, maybe try it on one and see...
David Young
Safety First !!!!!!
5:05 PM
vt
Haha
I've been questioned about laughing at the Internet to jokes from people I've never met and some I may never meet.
The thing that confounds her is that our bond is taking a dirty tool that cuts done trees and make it cut trees faster?
Yes that's exactly right honey.
I think we are all a little crazy in good company and supported by some tolerant loving women.
I'll look for more pics. Brb
Mattyo
Youtube speciawist
5:05 PM
Farmington, CT
Indeed the 199 carb or the el42 may be the ticket here. who knows.
i think everyone here knows that the ny gtg results really took the wind out of my sails, and even though the dyno was really cool and encouraging, yesterday I had another setback. the best possible 372 I could possibly build was sold wednesday, and came back thursday after 10 minutes of running w/ a scored top end. its oem 51.4 P&C....ported. tore it down, can't figure out the cause even after pressure testing and teardown. really discouraging when you do everything right, can't figure out the cause, and still there is a catastrophic failure.
i really need to step away from saws for a while guys... i'm way too frustrated.... i'm not having fun and not making money. :(
