Ported 350 results
Mattyo
Youtube speciawist
3:05 PM
Farmington, CT
Just think...I spent the last two years doing 350s...
Now I'm facing the reality that the hours of modding may not have good bang for buck.
isaaccarlson
2:05 PM
Colfax, WI
The biggest breakthrough on a 350 is probably when someone grinds too far on a port wall.:crazylick: There isn't much left after porting.
Tor R
Novice, Leg model #2
9:05 PM
Mandal
Me and @Tor R are cooking up some ideas for our 350 projects and @rattler going to do some piston work so we will see what we can come up with. Nice looking saw btw.
I am no porter of quality :) my goal with 350 will be based to learn the wheel, widen ports, mm, 357 carb&filter, and make the saw as cheap I can.
I never had in mind to get one 350, getting parts to 346 projects eventually made so I had 80% 350 so I thought, why not :D
isaaccarlson
2:05 PM
Colfax, WI
I know I left a lot on the table with this saw. I didn't lower the jug, I didn't make a popup piston, and I didn't change any timing(if it is needed).
All I did was what most folks would be able to do with basic tools. I can only imagine what the results would be if I did all that too.
I might see if I can pick one up on craigslist for cheap and work it over real good for my personal use.
Tor R- have fun with your build.
3:05 PM
I've got 2-3 I'm gonna be porting soon. One will be with an OEM 346 top.
Matty, I have no idea how your saws weren't much faster than a stocker. It makes no sense.
Your 350 wowed everyone last year. You said it lost a bunch of compression, that may be the reason why. I think you need to add cabers to your builds.
It's a head scratcher for sure MattyO. But don't let it get you down. Opening your muffler alone may be the answer.
I still remember trying to stall your 350 in a log and being unable too. I remember your grin too, it crushed an 026 I had done at that time.
To the OP, nice gains. Did you use the 44 or 45mm top end?
I can see advancing the timing helping, and an unlimited coil.
Simondo
8:05 PM
UK
Matt...I have had a few 350's and have run them stock other than a moderate muffler mod , there fairly strong in timber up to 10in. Im personally puzzled like many others how the stock saw can be so close "Regardless" !
Please excuse if this has been asked in the past but...Is the stock saw "Reliably " stock . Can what it actually is be verified ?
I echo what drf255 has said too...All things being as there supposed to be this isn't a "Logical" situation !
Simon
Jimmy in NC
3:05 PM
North Carolina
Your 350 wowed everyone last year. You said it lost a bunch of compression, that may be the reason why. I think you need to add cabers to your builds. ......
You can over port a saw. It will run like crazy for a very short time. The rings quickly wear out and the saw falls on its face at that point as compression suffers. Actually seen it more in 346/350 saws than others. Everything is a trade off...ported increases ring wear but makes more power. Now if modded conservatively the acceleration of ring wear in minimal.
Also ive seen lots of people looking for a 350, 346, etc to mod and run a 20" 3/8 setup stongly. Those saws were never intended for that...a port job should push a good saw to great, not add bar length to what it wears.
Mattyo
Youtube speciawist
3:05 PM
Farmington, CT
Lots of good points fellas. Saw #5 has new caber rings as of just before the NY gtg.
Lots of discussion to be had tomorrow. ..or maybe tonight if I can get there.
Chainganger
2:05 PM
Minnesota
It would make sense that oil choice could be critical on these builds as well as choice of rings.
P.M.P.
Stiff Member
3:05 PM
Michigan
Nice job on your 350.Its awesome when you can see your own work run. I have a 350 torn apart in a box need to get together has a 346 aftermarket jug and slug with it.
Mattyo
Youtube speciawist
3:05 PM
Farmington, CT
I'm pretty sure my wife would not appreciate you posting a picture of her sister sorry gentlemen but you'll just have to use your imagination
David Young
Safety First !!!!!!
3:05 PM
vt
close?
