dannyupsolate
- 1:37 PM
- Jul 15, 2016
- hawk pride alabama
2 on H kinda worries me. it is at low end of range. did it lose power at 3 turns on H
most folks that work on them will have several bad carbs laying around with that spring. the 4218 that won't idle right try loosen and reseat carburetor they are bad at sucking air at seal between carb and intake.
H is not in play at idle. Sometimes saw will speed up when you turn L screw in a little.
L screw must be out enough to allow for easy start in enough to allow idle. When you pull out choke on the 4218 it activates a fast idle. Every thing we are talking about here assumes we have a warm engine with choke fast idle not in play. Many saws will move chain a little at idle. It's a chainsaw not a swiss watch
