Piston/Base Gasket/Cylinder Measurements
Billy Currie
4:07 AM
Asheboro, NC
I would like to start a thread for providing measurements of cylinders, pistons, and gaskets. This is with the intent of seeing what's close of other models and what isn't without spending a lot of money on something that doesn't work. How close to the original measurements should be at the discretion of the assembler. If clarification is needed of a part, ask in the thread or message. I will add more as time permits. If all you have is one part, add it. You don't need everything to add a model.
I'll start with something odd, a Partner 7000, OEM parts. Here is a picture of what I have.. the wrist pin is 12mm, piston height from bottom of skirt to the top of the piston is 40mm + 2.2mm for the dome with a total height of 42.2mm. Sorry I missed that.
Nutball
3:07 AM
Mt. Juliet, TN
Excellent idea. I'll get measuring. I'd be interested in the dimensions of a 3120xp.
Is AM good enough reference? I expect it to be at least mentioned as an AM reference.
Billy Currie
4:07 AM
Asheboro, NC
True, after market and manufacturer would be a good idea. I added that to my post.
10:07 AM
A list of desired measurements would be of help so that everyone measures the same dimensions.
Something like the OP's drawing devoid of measures so it can be printed?!
I do not build saws, as such I do not know which measurements are desired.
Billy Currie
4:07 AM
Asheboro, NC
Like a drawing of a piston with all dimensions labeled: dimension A, B, C, etc. I see where you are going with that. I think @kneedeepinsaws was suggesting a similar idea as well.
Nutball
3:07 AM
Mt. Juliet, TN
It would be nice to have a standard dimension sheet, a drawing of piston and cylinder with blank spaces marked for each place to measure would be nice, so people can just copy the sheet/image, write in their measurements without forgetting any, and post it.
Billy Currie
4:07 AM
Asheboro, NC
Ok, did I leave anything out that needs to be added? Or, is there measurements here that don't need to be there?
Nutball
3:07 AM
Mt. Juliet, TN
Unless I'm missing something, maybe distance from pin to crown.
Billy Currie
4:07 AM
Asheboro, NC
Gotcha covered. I didn't make that measurement from the center of the wrist pin, I went from the top.
Nutball
3:07 AM
Mt. Juliet, TN
Left to right like a book:
660 FT
A 54mm (53.74-53.93mm)
B 12mm
C 42.93mm
D 35mm straight across
E 14.5mm
H 3.50mm
I 2.75mm
J 1.2mm
K 17.06mm
L 13.9mm
660BB white box
A 56mm (55.72-55.94mm)
B 12mm
C 41mm
D 35.6mm straight across
E 14.8mm
H 3.2mm
I 2.54mm
J 1.2mm
K 17mm
L 12mm
395 Hwy
A 56mm (55.76-55.92mm)
B 13mm
C 48mm
D 39.1mm
E 18.75mm
H 3.40mm
I 3.55mm
J 1.16mm
K 20.5mm
L 14.5mm
395 popup Hwy
A 56mm (55.75-55.93mm) Observed the thickest dimension is front to back, .1mm narrower on the sides, didn't check above pistons for this.
B 13mm
C 48mm
D 39.1mm
E 18.75mm
F 38.4mm
G 0.5mm
H 3.40mm
I 3.55mm
J 1.16mm
K 20.5mm
L 14.5mm
395 BB popup Hwy
A 58mm (55.74-55.92mm) Also thinner on the sides by .05-.1mm
B 13mm
C 48mm
D 40.4mm straight across as with all the other pistons
E 18.8mm
F 39.5mm
G 0.5mm
H 3.32mm
I 3.65mm
J 1.16mm
K 20.5mm
L 14.5mm
026 Warhawk
A 44.7mm (44.56-44.68mm)
B 10mm
C 32.35mm
D 27.95mm
E 13.7mm
G 1.35mm?
H 2.65mm
I 2.77mm
J 1.2mm
K 14.7mm
L 7.65mm
029 white box
A 46mm (45.84-45.92mm)
B 10mm
C 36.8mm
D 36.6mm
E 14.5mm
H 2.7mm
I 2.5mm
J 1.5mm
K 15.36mm
L 11.4mm
028 Hwy
A 46mm (45.80-45.95mm)
B 10mm
C 35.7mm
D 30.6mm
E 13.6mm
F 22.7mm
G 2.55mm
H 3.5mm
I 2.7mm
J 1.5mm
K 15mm
L 10.7mm
028 FT
B 10mm
C 35.45mm
D 30.6mm
E 14mm
F 22.5mm
G 3.65mm
H 3.5mm
I 2.7mm
J 1.5mm
K 15mm
L 10.7mm
365 Warhawk
A 48mm (47.73-47.88mm)
B 12mm
C 42.52mm
D 21-38.75mm
E 16mm
H 3.35mm
J 1.5mm
K 16.65mm
L 13.85mm
039 popup Cross
A 49mm (48.67-47.95mm)
B 10mm
C 37mm
D 37mm
E 13.9mm
F 27mm
G 0.9mm
H 3mm
I 2.5mm
J 1.5mm
K 15.5mm
L 11.5mm
200t white box
A 40mm (39.86-39.94mm)
B 9mm
C 30mm
D IN23.5mm, EX25.4mm
E 10.5mm
H 3.35mm
I 2.5mm
J 1.5mm
K 11.9mm
L 9.1mm
390xp OEM
A 55mm
B 13mm
C 46.65mm
E 17.6mm
H 3.35mm
I 3.4mm
J 1.2mm
K 20.15mm
L 13.5mm
590 OEM
A 45mm (44.9)
B 11mm
C 40.70mm
E 17.3mm
G 2.2mm
H 3.0mm
J 1.5mm
K 13.5mm
L 16.2mm
Nutball
3:07 AM
Mt. Juliet, TN
I found this pic of a 070 piston from aliexpress & ebay
58MM-Piston-Assy-Piston-Rings-Pin-Fits-For-STIHL-070-090-Chainsaw-OEM-1106-030-2000.jpg_q50.jpg
Sumbuddy told me they had a 13mm pin, but if the piston really is 53.3mm tall, that's too tall for my project anyway. I'm glad I didn't buy one. Looks like pin center to skirt is about the same as a 395, but way taller above.
Billy Currie
4:07 AM
Asheboro, NC
I have a box of pistons to add, I haven't had time, that one is not one of them. Sorry.
