Billy Currie
- 1:14 AM
- Sep 21, 2018
- Asheboro, NC
I would like to start a thread for providing measurements of cylinders, pistons, and gaskets. This is with the intent of seeing what's close of other models and what isn't without spending a lot of money on something that doesn't work. How close to the original measurements should be at the discretion of the assembler. If clarification is needed of a part, ask in the thread or message. I will add more as time permits. If all you have is one part, add it. You don't need everything to add a model.
I'll start with something odd, a Partner 7000, OEM parts. Here is a picture of what I have.. the wrist pin is 12mm, piston height from bottom of skirt to the top of the piston is 40mm + 2.2mm for the dome with a total height of 42.2mm. Sorry I missed that.
