Black Dog Chainsaw
Mak-Crazy
- 10:33 AM
- Jan 8, 2016
- Indianola, IA
I was just making the challenge real for you.I don't got a 260. haha I was joking.
a couple of you need to go back and read my 029/039/290/390 carb statement...Me neither but I want one
Got pics and measurements of those carbsa couple of you need to go back and read my 029/039/290/390 carb statement...![]()
they are a direct replacement fit from one to the other. If you are asking venturi size... no I don't have that info. Considering the 029/290 carb can feed a 64cc 039/390 top end without a problem... I'm sure you'll feed more fuel/air mix than the stock wt194 50cc carb.Got pics and measurements of those carbs
IL look into thatthey are a direct replacement fit from one to the other. If you are asking venturi size... no I don't have that info. Considering the 029/290 carb can feed a 64cc 039/390 top end without a problem... I'm sure you'll feed more fuel/air mix than the stock wt194 50cc carb.![]()
I have a NOS 3/8LP bar in the shop hanging on the wall waiting on my 026pro with heated handles build. I bought it online by accident thinking it was 3/8 standard. Happy mistake!029/290 carbs come with smaller jets than the 310/039/390 carbs. Better off with the larger jet 310/390 ones.
As for the OP, the Walbro 22C is second only to the Walbro 194 in quality/performance on the 026/260 line. Fully tuneable, and it will run it just fine. And if you want to make that 260 cut faster, put a Picco/low profile B&C and rim on it. With the new Stihl Picco PS full chisel non safety chain it will rip through the wood. That is what I have on my 026 now. Not easy to find those bars and rim drives in the US though. They sell them as a kit for the 261 in Europe (but not here).
Nathan, I have a couple 026, as well as an 039 carb. What is normally done to accommodate an air filter?I have a NOS 3/8LP bar in the shop hanging on the wall waiting on my 026pro with heated handles build. I bought it online by accident thinking it was 3/8 standard. Happy mistake!
As for the 290/390 jetting difference... meh.. they are still jetted bigger than the 194 and 22b/c. And either of the farmboss carbs are readily available AM or OEM. The question is if the AM 290/390 carbs are jetted to the 290 size or the 390 size??? They only make one for all three saws so which jetting did they go with?![]()
No. Just double checked. It's definitely a wte-827. Fully adjustable and had a high limiter.870?? Haven't seen that one myself.
That would depend on whether you are ported well enough to need the higher fuel and air volume.I do not waste my time on aftermarket carbs, or much Chicom stuff on saws for that matter. So I cannot answer that question. All I was saying is that the 310/390 carbs are jetted bigger than the 029/290 carbs, and since you want to shoehorn in a larger carb, it would seem that the larger jetted carb would be the better choice of the 1127 series OEM carbs.
