One ring vs two
1:06 AM
Geez, and I thought that thread went bye bye because I said muh MM work saw sticker make muh saw go faster...........what a relief! I thought this was the no but hurt zone. Anyhow, how do I get muh two posts back that I lost. I was hoping to win that huskovarno:p
Post two more times........click your heels together and say "I need that saw......I need that saw".
paragonbuilder
2:06 AM
Norwich, CT
I actually know why,the better running saw had better transfer timing and didn't need to be raised as much to achieve the same timing.
Why does a better starting point help if you are porting to the same degrees?
jmssaws
Banneded
1:06 AM
I've often wondered if two things rings creates more or less drag than one thick one?
Say you have two 1.5mm rings vs a single 3mm ring. Which has more drag and dissipates heat better? The two thin ones because they are a smaller mass and can cool faster? Or do they seal so well they aren't lubed as well as the single? What if dog really ment cat?
Deets066
AKA Deetsey
2:06 AM
If you start out closer to your desired transfer degree, the final transfer opening won't be as tall. Smaller opening= better transfer velocity
jmssaws
Banneded
1:06 AM
I guess you could fowl the ring land and hang the bottom ring I it.
jacob j.
Only the weird
11:06 PM
Coastal Oregon
I'm going to say two rings equals two edges in each direction which equals more drag. One big ring is a bigger heat sink than two thin ones.
But- two rings travel the surface of the cylinder (riding the ups and downs of the surface) with a lot more flexibility. Think of it as a train either with one long car, or several short cars navigating a track with curves.
exSW
'Cause Thomas is a poopyhead
2:06 AM
United States
Nope,wrong analogy. More wheels,more rolling resistance. And pulls through the curve harder.Trust me.
