One ring vs two
paragonbuilder
5:28 AM
Norwich, CT
What do you all think of leaving out the bottom ring on a 201t?
paragonbuilder
5:28 AM
Norwich, CT
But it would be cool to get gains this way as well!
spencerpaving
5:28 AM
central new york
Combustion pressure forces a ring down to the bottom of the ring land and out to the cyl somewhat....by lapping the bottom side of a ring you get rid of the highs and lows and it seals better on the land of the piston....only really works on new pistons cause on used pistons the ring lands are already deformed a little
jmssaws
Banneded
4:28 AM
Gotcha
paragonbuilder
5:28 AM
Norwich, CT
Have you seen this increase compression Brett?
paragonbuilder
5:28 AM
Norwich, CT
And I'm guessing you do it by hand and avoid the ring pin?
spencerpaving
5:28 AM
central new york
It's a old Karting trick...I do it to every new piston....it's hard to notice a comp increase....but ya ever notice blowby discoloration on the side of a piston....not sure if it's actually from bad seal on the cyl or bad seal on the ring land
