OK, battle between two legends: 288xp vs 394xp
RIDE-RED 350r
6:05 PM
Blossvale NY
I have a 281. Is there much difference between it and a 288. I like it, it's pretty stout and fast, makes me wonder what a few more cc's will do. I'm not sure comparing a 288 to a 394 is really fair, I feel a 066 and 390xp would be more evenly matched as far as cc's go.
After seeing some of the vids posted by the fellows here, I certainly concur. ;) I expected the 394 to have an advantage due to it's larger displacement, but I didn't expect the difference to be as noticeable as the videos posted clearly indicate.
I was curious about the 288 due to the massive following they have and was wondering if they were an exceptionally good design causing them to punch above their weight class... A factory-freak of sorts. I've run 395's and 372's but never laid hands on a 288. After taking in the info here, I am no less convinced that the 288 is a great saw that has earned a well desrved loyal following. However, it seems to me based on the info and videos posted that the 390 does everything a 288 did but with better AV characteristics. So for me, I think that if I were to decide to add a saw in that size class to what I have, I would likely gun for a 390. Unless of course a good opportunity in the form of a 288 presented itself..
I would also add that after taking in the info posted concerning the comparison between the 394 and 395, I'm kind of glad I got a 394. ;) :D
One thing I know after all of this, I have come to really enjoy picking up blown/neglected/hopeless powerheads on the cheap and making them run again! I can't go drop $1200 on a new 395 at the drop of a hat, resurrecting them makes them much more affordable for me.
Wolverine
dilligaf
6:05 PM
Heck yeah! I paid $100 for mine. It was in pieces in a tote and quite the oily mess.
New seals, Randy's advice to removing transfer, a Meteor and away I went. Think I had about 300 in it after a few misc parts and a 24"b/c.
Simondo
11:05 PM
UK
Hi Joe
I guess this could" also" come down to folks collecting the 200 series of saws. Your going to want a 288 in the mix regardless of comparisons with other saws. Taken on its own merit its a nice saw plus a good mod saw .:)
idiotwithasaw
5:05 PM
Ky
Even if you spend more than you would have buying a runner, you are at least able to spread the cost out over time on parts. Think of it as interest, lol.
Sent from my HTC One using Tapatalk
38f20
6:05 PM
Loganton, PA
I like them both. I agree about the 288 not being near as smooth as the 394 but the weight difference makes up for it. I've got more in my 288 than I could get for it but it was fun to build and it gets lots of use. Neither are ported. image.jpgimage.jpg
old guy
Love me some Husqvarna
5:05 PM
Becker Minnesota
You won't be flogged by me. My 281 powerhead is as new, the guy I got it from said it sat in a house he owned for 20 years or so.
When he brought it to me I pulled the plug and put a little flex lite in there & the top of the piston was still white, I could read the AB letters on it and could see clean casting in the exaust port.
The chain, clutch, rim & 28" bar were not new but in good shape.
Me being a bit aged & battered was unable to start the thing till I put a D handle on it, it starts cold with 3 to 4 pulls.
I really have no use for this saw but it's mine for now, maybe someday somebody could pry it away from me with a long green lever.
John
Mark71gtx
6:05 PM
Fuquay Varina, NC
I have never ran a 394 or a 395. I have a 288 XP Lite and I really, really like everything about that saw. If a 394 ever crosses my path I might have to own it based on what I have read in this thread. The 288 still ain't going anywhere though...
Jimmy in NC
6:05 PM
North Carolina
We can fix that...well...I'll at least let you run one...
Jimmy in NC
6:05 PM
North Carolina
I will certainly take you up on that offer!
I have a tree to put down at my rental in FV...don't know how booked your weekends are, but ill let you know when. I also have a pile of logs at the shop if you just want to knock some cookies off...couple big pines in it. 1010/401 is the shop..
riverrat2
Semper Fidelis
5:05 PM
N. Orange County, TX
Mine is still together although I took it to work with me yesterday and gave it an initial cleaning it needed quite badly. Also ordered a Meteor 394 spec piston the other night too.
It may not need it, but it's getting a bottom-up overhaul and a little grinding too of course. ;) My goal is to make it better than new. Well, other than a few scratches and worn off paint anyway...
Heck that patina look just gives them character!!! I ran my freshened up 288XP at the BBQ firewood pile today,,, It just came back from tha tree monkey's lovin center !!!!
I had to tweak the Carby a bit to get it to act right,,,,
Woot Woot!!!!!~ that freaking thing rips I tells ya!!!!! Thanks Scott,,, @tree monkey I really like it
A 395 is smooth
Way!!!!!!
