EFSM
- 1:28 PM
- Apr 30, 2024
- Extreme southern IL
Just making sure you realize that NGK heat ranges are backwards from most other manufacturers; the higher a number the cooler the tip. Echo uses 8 heat range plugs on almost everything except the 2620 engine and they have no issues with carbon buildup on the plugs. Like was mentioned, that is almost always a result of the carburetor settings being off.No, you haven't seen before and after. I have. Not once, but twice. So you don't like it sorta like Regan MacNeil when holy water was thrown onto her possessed body. Here is a video of some Echo Advisory Group member bragging about Red Armor. Notice the nice and shiny piston crown. This srm-2620 with a crm7h plug runs hotter than a br800 with a cmr6h plug. I edited to include a bit on Regan MacNeil.
