Can someone clear the air for me. I keep reading that an OE top end can go on a xtorqs case. But a xtorq top end can't go on an OE without modifications.  The bottom of the piston will hit the case portion of the lower transfers! I have a 1998 365 special in front of me and I installed a xtroq piston just to see what people mean. The piston isn't touching the transfers! Did Husqvarna use a different case with the 365 vs 372? I've actually looked at an new xtorq case and the  transfers are deeper.  but I've also compared it to an OE 372 which had shallower transfers. By the way yes everything is OEM.
