Oak
mdavlee
Hillbilly grinder
1:32 PM
TN
SO. If I mill a log with 3/8" chain I may have to resharpen the chain every cut? This will be my first time milling, so looking for any and all advice I can get.
It will be a green red oak tree about 18" in diameter.
What Zinzzer product should I use for the ends?
My experience with square files milling chain is 45-60 bd feet before it’s needing pushed to finish a cut. If there’s no bark and the dead media on the outside that helps. That’s 3/8”. I never used much 404 since I mostly milled with 046s and a 395. The 88 I switched to 3/8” so I did st need another roll of chain around.
Dougbert
10:32 AM
Western South Carolina
IMHO sanding sealer won’t seal the endgrain. I did 2 coats each side with this stuff
I've been using yellow wood glue to seal my ends. First coat I add about 25% water so that it soaks in better. Second coat same or straight out of the bottle. The off-brand stuff is pretty cheap.
I think a PVA drywall primer might also work, but not sure how well it would do outdoors. Latex paints will breathe, so maybe not the best sealer.
Moparmyway
Its just a saw
1:32 PM
In a meeting
Wow those slabs look great!
Thanks, they’re 2.5” thick and were going to be 12’ long, but I had to cut the stick down a little bit so the 12’ rails would work
Nice. Hit no metal? That blueish coloration makes me nervous.
None (yet), I believe that discoloring is from carpenter ants. It begins below the felling cut and runs a few feet into that stick. Was a tree in the woods most of it’s life
Beautiful
Thanks Jeefus, there’s one board with a crack running about 30” from the end, the others are perfect !!
Wolverine
dilligaf
1:32 PM
Sounds like you got to it just in time. Those slabs look heavy, did you have help moving them around?
RI Chevy
1:32 PM
earth
I need to make a nice set of plates for front and back. Or maybe buy a cheap ladder. I used some 2x4s that I put together.
I milled mine on sight and had to carry them out. HEAVY...LOL
Moparmyway
Its just a saw
1:32 PM
In a meeting
Yuppers, two people on the end opposite of the one I took for a couple of them, most of them were one on each end
Angle iron, 2x4’s, ladder....... anything to get that first straight cut
1:32 PM
Tamarack/Eastern Larch. A odd and very intriguing tree. Fairly hard wood considering it is a conifer. The wood has a high silica content so it tends to dull chain fairly quickly. Turned out pretty nice, I’d say it was worth the trouble to mill it. CFE05207-49CD-481E-BE68-8EA41D1664D4.jpeg03B2FD73-D3CB-4AE8-9D27-3D6AEF239CB5.jpeg
