NSP2. Cuz PA WiFi sucks
Status
Not open for further replies.
12:39 AM
Having to learn facebook blows and not in a good way!
Morning
Back up off muh Styx mang
Do you make them different than factory?
3/8" is a maybe 404 no problemo
You *frenching snobbish prick
Absolutely
Found a spiny thingy, again ffs....guarding this one with a shotgun.
"Go ahead....make my day"
"Yu feelin' lucky, punk?"
Thoughts in a popup cloud...
Everything is within earshot now.
You'll be leaving here in a bag :watchout:
lol medicinal ?
qurotro
Cookie Cutter
11:39 PM
Ar
usually when you punch them apart it shears a ring and if you try reusing there isnt enough to the chain strong enough
i personally wouldnt reuse them but i maybe a snob
I have like 100ish links in total. Feel bad to throw them away cuz they are new. Some Stihl and some Oregon. All 3/8 0.063. I have some Stihl straps lying around too. But thinking 7 or 8 joins would create too much weak points?
12:39 AM
the rivet holes are different sizes between Oregon and stihl
Pictures of your links
Definitive Dave
Piss Rev Mafia Member
12:39 AM
Central Ohio
You need ferrous material to locate.... and a expensive line locator. If it’s a plastic line you have the option of trying to shove a wire inside of it from the meter pit.. I like using a electrical fish tape the best.
I’d just let it run longer and make yourself a pointed rod and probe around where your best guess is..
Next would be a Shovel.
You can find pipe of any kind with a divining rod or even a bent piece of thin metal rod, i have done it plenty of times
12:39 AM
Good afternoon guy's
ray benson
11:39 PM
nw indiana
If you can keep the chain all one brand with matching straps should be OK. I tried mixing new old stock Homelite 3/8 with a new Oregon 3/8 and it didn't run smooth.
Status
