Noodling with the 462
Sagebrush33
10:43 AM
Upstater
Thith.
It's one of my least favorite phenomena.
If I'm not mistaken, you're runnin Hooskies? The 70cc and up saw all have fairly big dawgs? What are your thoughts on these?
Your advice may save me from spending coin on bigger dawgs. Besides wanting to experiment with the 261, I'm gathering parts for a 440 hybrid that I've yet to select dawgs for.
10:43 AM
I’m not understanding the bigger Dawgs being worse comments. I generally like the smaller ones myself because they give up less bar and our hardwoods don’t have thick bark.
My own 462 was equipt with 661 Dawgs from the dealer I bought it from, it’s what he had on hand. I didn’t want/need an R model and still don’t see the point in one. I haven’t had any issues, but I’m not a professional cutter either.
So are you saying the longer Dawgs create a shorter lever arm that will apply more torque to the bar and chain? Wouldn’t the user just lift less if they knew what they were doing instead of stalling the saw in the cut?
Also, the age old light vs heavy flywheel argument. Other than initial increased kinetic energy being available when load suddenly applied I don’t see how a heavier flywheel would make any difference during a short increase in bar pressure during a continual load event. I could see a heavier flywheel being better for limbing and for a stable idle, but that’s about it.
I’m not exactly certain how the longer dogs make it lock up, but they definitely do. I believe that with the points sticking further away, a minute movement upward by your hand results in a larger distance traveled by the bar.. And I’ve always been right there with you arguing about the torque versus fly wheel thing. And that’s all I was talking about was the initial hit.
I had a mini GTG this winter and pulled a new 462R out of the box and tried running it for a few cuts. We could not get it to make a cut with a 28 inch bar and RS chain with the oem R dawgs.
sledneck22
But, is the chain sharp?
9:43 AM
WI
It's give and take, like anything. I've noticed this exact same thing with my 462. I have the west cost dawgs on it too. I put them on the stock clutch cover. The reason I did that, was to more easily notch trees when felling. Those little dinky spikes sucked when lining up the undercut.
This is running a 28" bar as well. I've kind of learned to almost feather the saw in the power band more. The spikes definitely give you more control but if you file your chain with too much hook, boy it sure is frustrating.
I never put thought into the flywheel weight as being a key component to this phenomena. But it sure makes sense that rotating mass comes into play.
The reason I mainly use a 28" bar, is because I'm 6'3" tall. I hardly ever dog the saw when bucking less than 20" diameter wood because I'm mostly standing. So it hasn't really bothered me at all with the saw. And anything bigger than that, I just use the 2095 Jonny.
10:43 AM
Less hook and taller rakers would definitely help. I tilted the grinder back 5° from my normal and sharpened it without any noticeable difference. Probably should’ve tried 10° less. And it’s definitely not just the 462. Every saw will do it if you don’t have the correct chain for the setup you’re trying to run. But the 462 flywheel seems really light and I mostly attributed it to that because it’s more noticeable on the 462 than other saws of similar size
Cat 525
9:43 AM
Central Kansas
I am running a 462 28" with 8 pin equipped with the big dawgs. When doing the felling bore cuts it's not a problem. Bucking on the logs takes a bit of awareness of how you start the cut. I call it riding the dawgs. Some fellas can get along fine and others are locked up all the time. Husky or Stihl.
10:43 AM
The crank is probably not much heavier than a 60cc crank too since the stroke is the same as most 60cc saws. I’m gonna guess you guys try to keep that exhaust real low on the 462 when porting it? That must help a little.
10:43 AM
I know some guys raise it back up but I usually leave it down after machine work. It already turns a bunch of RPMs, so I try and give it more torque
dustinwilt68
Wilt Built Work Saws
10:43 AM
Southwest PA
Stock the exhaust w a gasket is only like 95-96 degrees, definitely not designed for torque out of the box, I lowered mine because I like a torquey saw, I still only run a 20" on mine and I use the dawgs sawmikaze has pictured 11226640504 and 11226640505. Here I don't really need a longer bar that often then a 20", if i do, typically grab the 066 or 394.
ferris
4:43 PM
Germany
How does it change with out gasket?
10:43 AM
My statement was more of a question than argument about the bigger Dawgs. I’ve never had the same problem, but it’s likely because of the way I cut. I never have the chains moving when I hit a log bucking. You’ve probably seen it in my vids, but I lay the chain on the wood and hit the trigger a few times to notch and then hit it.
Hitting the wood at WOT never made any sense to me other than limbing and racing/timed cuts. Seems like a recipe for disaster bucking, anything that wants to break is gonna from the rapid inertia abruption to the rotating mass.
I understand what you guys mean about the Dawgs now. Appreciate the explanation.
10:43 AM
The more you drop the jug over the piston, the more degrees of rotation until the exhaust roof opens.
So when you remove the base gasket, you are lowering the exhaust roof when you bolt the jug back on. I’m not sure how thick the factory 462 gasket is because I have never deleted it, but most factory metal Stihl gaskets are around .017.
Piston speed occurs in a sine wave fashion, so it’s the fastest at 90*. So the exhaust port opening will move the least of all the ports when a jug is lowered by degree, even though it’s physically being dropped the same distance as the transfers and intake port.
There is no other way to lower an exhaust roof than to cut the base (or remove the gasket) other than casting a new jug and having it plated. We are limited to what the factory gave us there. So you drop the jug to where you want the ex roof to open and then you need to raise the ceiling (squish band) to make the piston not hit at TDC. There are other limitations that occur with the whole thing as well.
Hope that makes any sense.
10:43 AM
The heavier the flywheel the more stored energy take a very heavy flywheel and a very light flywheel which one would offer the least amount of resistance to slow down.
For limbing I think a light flywheel with fast on the trigger spool up would be best and fast off trigger chain slowing down. A heavier flywheel takes longer to spool up has slower trigger response and getting off the trigger the chain takes longer to slow down.
Personally don’t think the flywheel weight has anything appreciable to do with spoolup. Take any saw you build with no bar and chain and spoolup is instant. Add B&C and it slows down. Want faster spoolup? Add a smaller bar and chain.
Not saying it has zero effect, just nearly zero.
10:43 AM
This is a 462 with factory Dawgs that aren’t that big. If you watch how I tend to start cuts you’ll understand why the bigger dawg phenomenon hasn’t happened to me.
Guess it’s a cutting style thing.
Your technique helps a little. I notice the phenomenon most cutting notches into hardwood trees. Cutting softer wood like tulip poplar (like in your above video), cottonwood, hemlock, white pine (or other pines/conifers) the phenomenon is mitigated. The large west coast dawgs were designed to purposely bite into huge thick barked trees out west. The hook on the bottom tooth points down instead of flat like stock dawgs. They need the saw to bite in the thick bark so there not holding it up and muscling it around in a humbolt undercut. More leverage. Keeps the saw steady when there trying to line up cuts in a big tree. Here the wood bark is thinner, trees smaller and the wood is harder. Different cutting techniques are also used (we don’t use the humbolt as often). Felling dawgs don’t need to be as aggressive. Aggressive ones tend to be counterproductive here. Just my opinion.
dustinwilt68
10:43 AM
Southwest PA
typically it changes the number around 2 degrees, a good rule is for every .010 you remove is close to 1 degree, I believe the 462 gasket I measured was .019, not only do you lower the exhaust but of course you also Increase compression also. I also have a lathe so cutting the chamber and base further allows me to achieve my desired numbers, along with using a degree wheel and right angle/ straight hand pieces. But honestly the Mustang Mike method of base delete, muffler mod and timing advance help these saws for anyone looking at doing things themselves that don't have special tooling.
sawmikaze
10:43 AM
steeltown
Buy the 064 dawgs for your hybrid.
Bigmac
7:43 AM
Maybe I am read that wrong. Flywheels make a huge difference on spool up, Similar to short bars or no bar, the less mass to accelerate the quicker the spool. Like putting an aluminum flywheel on a muscle car or lightening the flywheel on a quad, its noticeable
Bigmac
7:43 AM
I don’t like big dawgs bucking with small saws, the lower the point of the lower dawg hangs below the bottom of the saw, the more it increases the leverage. And the sharper the points are the more it bits and levers! stock dawgs usually are fine, some of the pro-safety 5 point dawgs are too much for me! Even the direction of the spikes makes a difference for me, I only like the big dawgs on big saws!
10:43 AM
I shoulda said that it applies to chainsaws. There’s just not enough real estate in there to fit something with enough difference in mass. Plus, fin design limits or helps spoolup.
The difference in a chainsaw is negligible because of the offerings. The 044 vs MS440 flywheel is a good example. The o44 is heavier, but not enough to make any real world difference. I’ve personally experienced the fact that there was no difference, but I bet the lighter one spools up a few microseconds faster. An 024 vs 026 is another. The 024 flywheel is heavier but spools up faster because it moves less air-the fin design of the German 024 flywheel looks prehistoric vs the Japanese made 026 flywheel.
Guys lighten flywheels all the time for racing, but it’s mostly to remove fins and reduce drag.
It’s not like an auto flywheel where it helps launch-I have a heavy billet flywheel in my Vette.
Flywheel weight does matter, but in a saw the amount of difference is small to unnoticeable.
