Mag Craft
- 12:05 PM
- Jan 20, 2016
- Carpenter, Wyo.
I would try another spark plug. I have seen new ones bad before. I have worked on a bunch of ice augers in my part time job. Every winter they come in for repair.
They are no different to work on than another 2 stroke engine. What does the plug look like when you pull it. Is it wet or dry or does it look normal. Have you tried half choking it to see what it does when you rev it. It might be lean from an air leak. I have never seen a coil that would idle but not rev, but there is always a first time. How does the piston look through the exhaust port, is it real wet or is it dry. Just looking for some kind of sign to help with a diagnosis. Also you said the compression was 160 PSI is that correct.
