Need some help with a 036
6:07 AM
I was milling with my 7900 and it started running weird. I shut it down and found the tygon impulse line melted off. It ran, but I knew something wasn't right
panteliss
12:07 PM
Europe
how good is theese tygons versus to oems , i hear many use them ?
decableguy2000
6:07 AM
WNC
6:07 AM
so cableguy it was the impulse line ?
decableguy2000
6:07 AM
WNC
Impulse line off the nipple.
Took the tank vent apart
panteliss
12:07 PM
Europe
when just the time you hit the throtle ??? just because you say that the saw pass the pressure-vaccum tests and start - idling very good
decableguy2000
6:07 AM
WNC
Idled for a few minutes, try to give gas and it would die. Would restart fine. I must of knocked it loose when pulled the stuff off I used to block of the carburetor or hooking up the linkages.
I want to think Mattyo had similar problem with a Husqvarna 394 that had a blocked impulse.
Jeremy
sefh3
6:07 AM
MI GO BLUE!!!!
Turn the h in. Too much fuel will bog it down.
