Funky sawman
Pony Power
- 11:41 PM
- Feb 10, 2017
- North idaho
*s-worde get out of hand quick with folks these days lol in before the lock!
Any updates?My buddy is in contact with the stihl tech manager for Atlantic Canada. They’re trying to get to the bottom of the problem so when they figure it out I’ll post what happened. It’s been pretty cold up there, usually below -30°C but all the other saws are working fine.
Not sure where you're at with these issues OP but we have had a couple come in with some similar issues. Something that we did that got the saws running again was replaced the stop switch. I know that seems silly but after replacing one unit and cleaning up a unit on the other they started right up and haven't skipped a beat since. Something I learned last week is there is an outside temp sensor in the stop switch, in addition to the pressure/temp sensor underneath the flywheel. You're cold weather could be affecting those things much more than other places. I'm over in north-central Idaho and it gets cold but not quite as cold as where you're at I think. If you haven't already I would seriously focus your sights on that stop switch or the sensor underneath the flywheel. Potentially the wiring going between the two from the ECU. Stihl isn't giving us much info on these saws so any knowledge that can be shared is extremely beneficial to all!
I agree, very good post from northwest saws!This is the kind of real world input I like. Even if it's not the op's problem. It is definitely something we should keep in mind.
Steven
Hey guys I’m hoping someone can give me some insight into what may be happening.
I have a friend of mine who is working in northern Ontario at the moment, extremely cold weather and the trees are loaded with snow. They have 6 500i’s on the program and none are running at the moment. 5 of them have less then 10 tanks of gas through them.
Basically what he’s telling me is that they won’t start and are flooding themselves, everyone of them. At first he thought maybe they were all frozen but he had them in a heated building for a day and they still won’t run. Take out the plug, extremely wet, dry it off and put it back in. A couple pulls and it will fire but die immediately and then just completely flood itself again. He’s tried everything that he can’t think of but nothing has worked and I have very little experience with these saws.
And before anyone mentions getting it diagnosed he’s 12hrs from the closest dealer. Any help on what could be the potential cause would be great. Thanks!!
Most stihls have a winter shutter to let hot cylinder air into the air box. I don’t know if they got these saws running but I’ve been told by a few local shops they’ve changed some stop switches because they contain an external temp sensor in them that will cause a no start situation if they fail. But this is only what I was told I haven’t messed with it myself.Shane, did stihl ever find a fix for this bllsht?
I run all brands of saw in below zero weather. Some saws, I have to build snap-on bibs that cover a portion of the flywheel fins and cover the space in between filter housing and cylinder housing.
Stihl no longer offer arctic provisions, which is bullsht.
Anymore info on this?
With zero stihl-arctic provisions available here in Alaska, I've been trying to find something better.
Some saws come fresh out of the box with these goodies:
Heated carbs and snap-on bibs to cover the flywheel fins(husq)
Then the echo cs 620 has probably the best winter setting of any saw I run:
a soft rubber port that runs hot air right into the filter housing.
Maybe just one step at a time rather than a series.So, you gonna do less and less labor on these saws until you isolate the issue, or do you think it could be a multiple issue problem?
Id move57 below zero, my jonson
Seen more than one saw not start at -38 on spearing trips. Couple huskies and a Stihl bur for some dumb reason the for wheeler and snowmobile started. Wheeler froze the crankcase vent though and popped the valve cover gasket pushing the oil out so needed to get towed back by the snowmobileIf a saw builder took $1500 from yah and it burnt up or wouldn't work in your conditions, the forum would grill the dude at the stake.
But when Stihl takes your money selling you something in your region, when they know it won't work, its ok.
57 below zero, my jonsered 2172 will start. Dmn thing has saved me from frostbite on occasion when I've gotten a heavy machine stuck in overflow. There's a heating element on the carburetor........
