Need advice on spark plug repair kit to buy?
twinstaged
8:55 PM
Ohio
Yeah could trim 10-15mm off for clearance
Lone Wolf
8:55 PM
Nj
I've got a homemade plug that I use, to line up in the mill i screw my plug in the cylinder. I then indicate two sides up and down. It's about 4" long once screwed into the cylinder. It will get you dead nuts close.
Fixing to threadsert a 660 cylinder.
Well you have more room than I do .
Lone Wolf
8:55 PM
Nj
I have a junk cyl here for practice I could send with the good one.
twinstaged
8:55 PM
Ohio
Yeah just buy one the oem branded cheapie kits and make it work and keep it in the toolbox for a rainy day IMG_6668.PNG
twinstaged
8:55 PM
Ohio
Either way really. Shouldn't be a hard job to knock out. Any of the other guys that commented sound like they could getter done too. Can you post a picture of the cylinder to see how buggered up it is?
Lone Wolf
8:55 PM
Nj
Matt can you measure that one and post a pic?
Lone Wolf
8:55 PM
Nj
I can in a bit.
Mattyo
Youtube speciawist
8:55 PM
Farmington, CT
It was a minor amount of dremel to get the roof out of the way. ...probably would have been ok even without doing that. But then again...my threads weren't buggard at all. So it kept it perfectly straight
Lone Wolf
8:55 PM
Nj
Lone Wolf
8:55 PM
Nj
There is enough metal left to tap , the threads at the bottom are 14mm
woodtool89
Randalls favorite member
8:55 PM
In a world of my own.....randal wishes
looks like you already have a kit and a plan, but just for future reference for anyone reading this...ive made my own sleeves before... solid aluminum threaded for NPT then drill/tap head for same size NPT, then mill flush, then drill/tap for spark plug (this can be done before installing the sleeve if theres clearance issues like the op's...
heres some pics of one I did for 18mm plug holes, I believe I used 3/4" NPT for insert size...
Mattyo
Youtube speciawist
8:55 PM
Farmington, CT
Nice....4 sure the key there is clamping it down to the bridgeport
woodtool89
8:55 PM
View attachment 83126 View attachment 83127 View attachment 83128 View attachment 83129
BTW those had a healthy amount of Loctite 272 on the pipe thread portion of the insert
