WillG
- 9:32 AM
- Oct 10, 2019
- Norwich CT
Ok thanks. I'll just modify the stock one.Not really
Mostly I just cut a fish gill back along the side behind the inner baffle.So are you on team "open the stock muff port" or team "dual port"?
Base gasket delete and muffler mod.are you planning to build this stock or bump compression and port it?
Stock.What are you doing with the bottom end?
It started out as a 340. Making it a 346.Subscribed. 350 is my favorite homeowner saw. With a well ported top-end, power to weight is killer.
New bearings/seals or putting the old ones back in? Sealant?Stock.
Keeping the original ones. Bearings are okay and will pressure and vac test once together. I'll have Dan advise me on what sealant to use.New bearings/seals or putting the old ones back in? Sealant?
Just so you know, you won’t be able to tell through his “fixing Huskies” comments, but Jeff’s favorite saw is a Husqvarna 262XP. Don’t let him forget that.Muffler bracket modified and painted.
Carb arrived from @Stevetheboatguy the other day so I checked it and just pulled it apart, ran it through the ultrasonic cleaner for an hour, flushed it with brake cleaner and compressed air and reassembled.
Tomorrow I'm getting together with Dan, Jeff (@RI Chevy ) and another guy and I'm going to work on reassembling it.![]()
