my 2153
MG2186
11:40 AM
Summer,IA
325 costs more
wanted all my saws using the same chain
to damn many teeth to sharpen
timed cuts were close to the same
Did the 3/8 take anymore power?
tree monkey
11:40 AM
wi
brake and front handle, second tree of the day. hollow tree about 28". hinge collapsed. pinched the bar, of course I was on the wrong side of the tree so the saw was on the heavy side. was swinging the tree. I had to get, saw ended up under it when it was all done. didn't think there would be much left of it. was able to lift the tree off with the skidder. was very pleased that's all that happened to it.
12:40 PM
Top handle is probably fixable....now that it's just a worksaw and all. Bent or cracked?
12:40 PM
most important is you wasnt hurt or under the tree . the saw can be fixed you take alot longer to get fixed
P.M.P.
Stiff Member
12:40 PM
Michigan
Does a 346 brake handle interchange?
tree monkey
11:40 AM
wi
finished off the morning as it was, put a used brake on it at noon. spent a hour or so getting the handle straight at the end of the day. it's good to go. heated handles are pricy.
see what I can break tomarrow:)
