MS462 Design Changes
Chief Cat Herder
7:36 PM
It also means that the extra old type top end I keep in stock ported is not of use to me now. I try to keep and extra ported cylinder in stock for most of the saws I do regularly. Now I'll need to replace this one with the new one.
If anyone is interested in buying this setup, send me a message. It comes with the piston, rings, wrist pin, clips, muffler that is port matched to the cylinder, heat shield, gasket, and front cover.
20210822_140011.jpg 20210822_135956.jpg 20210822_135952.jpg 20210822_140030.jpg 20210822_140020.jpg
Chief Cat Herder
7:36 PM
I figured it would come eventually.
See anything you would consider an "improvement" ?
Not really. They just decided that the divertor under the piston wasn't needed. That makes it simpler.....
Also to consider is that there was a rash of broken pistons on the 462. This change could be more about strengthening the slug than anything else I suppose.
Chief Cat Herder
7:36 PM
Randy any idea of serial number when this change happens? Any external way of knowing?
I have no inside info.....yet. I'll try to find out.
Sticker on the front of the new saw is silver. That's the only change I can see.
GCJenks204
"Special Buns"
7:36 PM
Winnipeg, MB
Id be interested in what you find out. I’m more interested in one again now that I know the 462 is now available in an Arctic wrap version.
Chief Cat Herder
7:36 PM
got to be a SB on the change no ? How can they make such a radical design change without a SN to associate it with ? anybody with access to the current Stihl Bible ?
I'm sure there is a service bulletin on it. But Stihl recently locked me out of their website.
